- Thank you received: 8
12 Torque Specs?
- Justin Kerns
Justin
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
- Ivor
You may have already checked it but if not this may help you get an oil tight seal . I have found that If a pressed steel oil pan has ever been over tightened or removed and replaced a number of times the oil pan gasket face at setscrew locations becomes distorted, this can be checked easily by eye with a straight edge or straight edge and feeler gauge. If distorted It can be rectified by gentle blows with a hammer while holding the oil pan outer face against a suitable surface like the edge of a steel work bench. If a neoprene cork gasket is used it will easily compress and extrude adjacent to the setscrews if over tightened. For tighting I use a 1/4" drive socket set and tighten just enough to start compressing the gasket which would be about as tight as others have sugested and easily achieved if using a screw driver. I tighten all screws equally and follow up tighten after car has been on a run. The torque required is too low for my 1/2" drive ft-pound torque wrench but a 1/4" drive inch- pound torque wrench may help with repeatability if you have one.
- Mike Dube
mikespeed35 wrote: A tip for reinstalling your pan gasket or other hard to position gasket mounting. I read this tip in SK Mag. years ago and it works great.
Great tip Mike, I did something similar with the old head bolts to aid in locating the head.
8-100A
@Mike:
This is a great tip that I learned from the original "old timer" in my life (my dad) long ago. It works just as well when putting a fan back on a water pump in tight quarters (my 37 Buick Roadmonster is otherwise impossible) and any three-hand multi-bolt have-to-retain-alignment attachment scenario.
Replacing a bolt-attachment with a permanent threaded stud and nut can be helpful also. I did this for the 40 LaSalle's fuel pump attachment where the spring tension of the pump defied all attempts to start the two installation bolts. By using studs of sufficient length secured in Locktite Blue in the threaded holes in the block I was able easily to draw down the pump with nuts on the studs. One could then replace the studs one at a time with the original bolts, but I didn't bother. I considered--and still consider--the studs to be an improvement to the original design.
I did the same with the LaSalle and Buick starter motors which also require three hands to install.
- 61xlch
Regarding cylinder heads and oil pans these torque specs are not useful, because of other limitations, f.i.:
- material of oil pan or cylinder head (f.i. aluminum or steel)
- construktion, stiffness (warpage, detortion)
- material of the gasket
For unknown cylinder head torque specs I use the specs of other similar engines with known specs. For oil pans made of sheet metal and cork gasket I have a torque wrench in my right hand installed <!-- s;-) --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s;-) -->. Just hand tight as if you use a screw driver for slotted heads....
After 500 miles you should check these screws and tighten if necessary.
Good luck.
Andy
- Justin Kerns
Now how do we determine what grade the hardware is? They aren't marked with the modern hashes to indicate. Does anyone know?
Justin
Justin
- JOEL GIVNER
JEG
- gnutting
Jack Triplett
1931 Auburn 898A speedster
- Mike Dube
Not such a big deal on a pan tho.
8-100A
- Justin Kerns
Tom - Thanks for the tip. I found the article you mentioned in the 2008 #5 and #6 newsletters. While very informative all it says about installation torque is to follow the manufacturer's torque instructions.
Oh well!
Justin
Justin
There was an article in the Newsletter a few years ago about being careful about torquing cork gaskets. Search the Newsletter CD for it.
- Mike Dube
Unless you are very good with the wrench, I would still use torque wrench, just use a low value.
8-100A
- 61xlch
Oil pan screws need to be installed with a pretty low torque, in order to avoid distortion and gasket damage. "ver hand tight" sounds well.
Cheers
Andy
- Justin Kerns
When in doubt I'll just do it "very hand tight".
Justin
Justin
