Auburn front axle
- auburnandyscar
14 Jan 2014 23:22 #26653
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic Auburn front axle
Thanks for the replies.This is stamped on the top of the axle. I will look for some more numbers.
- JOEL GIVNER
14 Jan 2014 21:33 #26650
by JOEL GIVNER
JEG
Replied by JOEL GIVNER on topic AXEL
the numbers stamped should include a date code. The A usual signifies January. Following the A should be a year, i.e 31, 32 etc.
We document these axel stampings during Certification.
Joel Givner[/i]
Joel Givner[/i]
JEG
- Ivor
12 Jan 2014 20:43 #26637
by Ivor
Replied by Ivor on topic Front axle
I too was puzzled with the number stamped under the axle. I believe the number stamped is the Columbia part number. On our 8-77 the axle is lightly stamped 13061 in large 5/8 high numbers on the lower face. I also have a spare axle and it is stamped the same location, size and same number to the one on the car. I checked the Auburn parts book and it is not the same as the Auburn part number so I assume it is the Columbia part number.
- auburnandyscar
12 Jan 2014 02:48 #26631
by auburnandyscar
Auburn front axle was created by auburnandyscar
Today while working on my car I discovered numbers stamped on my front axle. The numbers are "A 19495". This axle is from an original car, and the numbers from the axle and its' original frame have no ( logical) correlation.
Am I correct to assume that the number on the axle is for it alone,only for tracking and potential service issues?
Curious...
Curious...
