31 Phaeton Sedan window seal mounting
- 61xlch
15 Jan 2014 16:55 #26663
by 61xlch
Replied by 61xlch on topic 31 Phaeton Sedan window seal mounting
Thanks Randy, I will have to make a small retainer rail for the non original seal.
15 Jan 2014 15:57 #26662
by RandyEma
Replied by RandyEma on topic 31 Phaeton Sedan window seal mounting
The orig seal was cast with a steel liner. So it was simply held on with a oval head slotted countersunk wood screw that was chrome plated.
- 61xlch
15 Jan 2014 13:48 #26661
by 61xlch
Might be, the question is how does it look like???
Replied by 61xlch on topic Re: weather strip
K Clark wrote: Bpys
I'm quite sure there is a metal rail that holds that rubber in place.
K Clark
15 Jan 2014 11:08 #26660
by
Replied by on topic weather strip
Bpys
K Clark
K Clark
- Brad Hoskins
- Thank you received: 11
15 Jan 2014 06:54 #26658
by Brad Hoskins
31 8-98 cabriolet
Replied by Brad Hoskins on topic 31 Phaeton Sedan window seal mounting
Andreas
I think the seal is just held on with trim screws in the rubber seal.
That is how the seal is held on the cabriolet post I have. No idea if original or not.
I'll try to get a picture on the weekend.
Brad
Brad
31 8-98 cabriolet
- 61xlch
05 Jan 2014 20:11 #26599
by 61xlch
31 Phaeton Sedan window seal mounting was created by 61xlch
Hello Phaeton owners:
at my car the window seals at the pillars and roof bars were missed.
I have now the correct rubber profile:
The question is how this profile is attached to the pillars and rails.
Is there a kind of U-shaped steel rail?
Anybody could show me a picture of this part?
Andreas
Andreas
