1931 head bolts- washers or not?
- DavidK
06 Jan 2014 18:53 #26613
by DavidK
Replied by DavidK on topic 1931 head bolts- washers or not?
My 32 only calls for one head bolt that is longer then the others. That's where my horn is mounted.
Dave
Dave
05 Jan 2014 22:53 #26606
Replied by Curt Schulze on topic Washers
All 34-36 GF , GG , GH , WF engines have washers under the head bolts.
- auburnandyscar
05 Jan 2014 22:15 #26600
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic 1931 head bolts- washers or not?
on my 12 cylinder the sub heads did NOT have washers originally. the surface where the bolts had been worked on and off over time were really poor looking, and 'correct' torque may not be obtained. I bought a spotface tool from MSC, some ARP washers, new bolts, and I think it looks great.
my car is a "mutt" so it will not be judged
- 61xlch
05 Jan 2014 16:06 #26597
by 61xlch
Replied by 61xlch on topic 1931 head bolts- washers or not?
My head bolts are all the same length. You would need longer bolts only in the case you have to attach a holder or something similar under one of these bolts. You should check out, if all bolts go long enough into the head thread.
Clean all threads carefully. Most threads go through into the water jackets, only 2 holes in the corners are closed holes. I also used a special heat and water resistant bolt lubricant. Curts washer would be fine, more than 1/8" thickness will do the job.
Anybody knows a recommanded head bolt torque?
05 Jan 2014 01:40 #26596
Replied by Curt Schulze on topic washers
I have some tumbled 316 stainless steel. Same as original. .465x .875x .165
- Brad Hoskins
- Thank you received: 11
05 Jan 2014 00:20 #26595
by Brad Hoskins
31 8-98 cabriolet
Replied by Brad Hoskins on topic 1931 head bolts- washers or not?
Thanks Andreas
That makes sense. I noticed that the 32-33 parts book also shows a high compression head and I wonder if that goes with the speedster and the washers?
Definitely a driver so it will get some washers!
Do you know what position the two longer head bolts go in? I do notice the there is no difference in bolt part numbers for the speedster ( with washers ) and the rest of the cars ( without washers).
How thick of a washer did you use?
Brad
Brad
31 8-98 cabriolet
- 61xlch
04 Jan 2014 21:10 #26594
by 61xlch
Brad:
It depends on your intention with the car. If you are looking for a concour winner you have to stay original (without washers). If you are going to build a driver, I would recommand you using washers, regardless if its original or not.
It spreads the load better into the head casting, less risk for cracks and provides a better torque tightening of the head bolts.
I used washers and slightly longer bolts. The bolts now overlap the complete thread in the block casting.
Cheers
Andreas
Cheers
Andreas
- Brad Hoskins
03 Jan 2014 20:18 #26586
by Brad Hoskins
31 8-98 cabriolet
1931 head bolts- washers or not? was created by Brad Hoskins
My new purchase might need a head gasket ( the alternative is not something I care to think about! Start with the easy stuff first!)
The engine has thick washers under the head bolts ( at least 1/8").
The engine in my other '31 has none.
The parts manual says washers were only used for speedsters but this engine is original to the car.
Why the washers??
Is there an advantage to using the washers and should I be using washers in any event on both cars? Somewhere in past hours of internet searching, I'm sure I read don't forget the washers but the page I was looking at is lost in time.
Brad
Why the washers??
Brad
31 8-98 cabriolet
