1932 dual ratio axle oil recommendation
- W. E. Snelson
01 Oct 2013 06:31 #26008
by W. E. Snelson
Replied by W. E. Snelson on topic Gear & Differential oil.
I have the original owners handbook for my 852. It specifies 140 oil for both gearbox and diff. That is what I have always used. These days its no longer an over-the counter item in Australia, so I order in Penrite in a 5 gal. drum.
Bill Snelson.
Bill Snelson.
27 Sep 2013 10:34 #26002
by
Replied by on topic gear oil
You need to remember that they put that very heavy gear oil in these cars for a reason, I'm a true believer that use what was intended. It is only thick when it is cold, once it is warmed up rolls just as easy. but a film stays on everything all the time.
My 2 cents
K Clark
My 2 cents
K Clark
- 61xlch
26 Sep 2013 19:53 #26001
by 61xlch
Replied by 61xlch on topic 1932 dual ratio axle oil recommendation
Before rebuilding my rearend I used 250W gear box oil from Millers.
After rebuilding with new seals I ?ll go for 140W differential oil.
andreas
andreas
25 Sep 2013 02:04 #25987
Replied by mikespeed35 on topic 1932 dual ratio axle oil recommendation
I don't now about 1932 but 35-36 Auburn has no bronze that I am aware of. I use GL-5 85W140 from Tractor Supply. It's about $50. for 5 Gal.
- Mike Dube
24 Sep 2013 20:31 #25982
by Mike Dube
8-100A
Replied by Mike Dube on topic 1932 dual ratio axle oil recommendation
I have been using that weight sourced from Tractor Supply successfully, at least so far, in both. We'll see what others have to say.
8-100A
- Auburn
19 Sep 2013 12:59 #25966
by Auburn
1932 dual ratio axle oil recommendation was created by Auburn
What weight or type of oil, such as bronze bushings compatible, is recommended for 1932 Auburn dual ratio rear axles.
I use Penrite 140w in my other 1930's cars..
And what kind of oil would work for the transmission ?
Rob
Rob
