Orpin Switch
Another thing I did was to enlarge the battery box and buy a larger 6 volt battery to fit in. Probably wasn't necessary, but I feel like I have more starting capacity now.
- Greg Frownfelter
double check for clean and tight connections
I like using the Optima brand battery 6 volt
lots of power and extra long shelf life, good
for storage periods
I agree 6 volt worked for years and should be fine
today. My experience with 8 volts has never been good,
the system isnt designed for it and bulbs dont like it
either
greg
- C.R.D.
No, I do not have the ohm values of a 6 volt or 12 volt brushes. I agree you should be able to check the resistance between the two. I was just relieved to get the starter working again and never pursued the matter after that.
Carl
Possibly one could check the resistance with a olhm-meter. Do you have the value of a 12V?C.R.D. wrote: Curt if it was only so simple. The 12 volt brushes were identical to the 6 volt, just not as conductive. The first rebuilder must have been unfamiliar with 6 volt, the second who was in his upper 70's and has done rebuilding for about 40 years just assumed they were correct as they were new. From now on my starters and generators go to the third one.
Carl
- C.R.D.
Carl
The 12V brushes is a new one on me, that is good info. I suspect they are smaller that 6V brushes.
- C.R.D.
On one of my other cars I had my starter rebuilt and it would barely turn the engine over. I installed an old starter and the car cranked over fine. The original rebuilder insisted the starter was fine and suggested I go to an 8 volt battery. After going to three starter rebuilders and numerous attempts to correct the problem. Finally one starter repairman discovered the problem. The original rebuilder put 12 volt brushes in the starter. Once the proper brushes were installed the starter worked great. Might want to check with the person who rebuilt yours and make sure they used the correct brushes.
Carl
- silverghost
Use Large size battery cables ~~~Not small 12 volt modern cables.
Your old original 6 Volt starting system should work just fine if properly cleaned-up and maintained !
If 6 Volts worked when new~~~It should work fine now today.
There must be some voltage drop in your battery cable system ,between the battery and starter, that is causing your starting system issue.
Using a 12 Volt battery today is just an un-necessary Band-Aid repair for a poorly maintained original 6 Volt starting system !
I had one on a POC '52 Willys Jeep driveway plower-outer, and it was the difference between having an operable Jeep and a flower planter.
I ran this two-battery arrangement and switch for several years with no problems.
- michael arata
