Mouinting tires
- Mike Dube
8-100A
- Mike Dube
Taking it to her first cruise nite of the season later today.
8-100A
For certain things POR 15 is a really great product. Applied to a casting; for example a front axel. After it is cured it can with stand a sharp blow with a hammer and not chip. The semi-gloss is great for under the car hard parts.mikespeed35 wrote: Curt, I used Rust Metal Primer in the 60's, Way before Por-15. I can't speak for Por-15 as I have never used it.
If you get it on your hands and it cures , you have to wait until it wares off.
- auburn653
- Mike Dube
I haven't used POR yet, but no, its just paint.
www.rustoleum.com/CBGProduct.asp?pid=41
I actually have a old quart that I'll brush on. Four of my wheels are pretty good, one is a touch rusty, but nothing extreme.
8-100A
Is that similar to POR-15?mikespeed35 wrote: I am a fan of that product. Have used rusty metal primer many times over the years. Can't remember a time it has let me down.
- Mike Dube
mikespeed35 wrote: Did your tire tech. say anything about the beads inside the tubes to balance.
I didn't bring it up, since I had already decided to go more traditional. Seeing Joel's comment makes me think the shop probably knows about beads as they do a lot of truck tires.
Initially, I had planned to mount them myself & perhaps use the beads. Based on feedback here and figuring I'm no pro & would likely pinch at least one tube, the shop is going to get the job. Now waiting for the wet weather to leave so I can paint inside the rims. Was going to use a Rustoleum oil base "rusty metal" primer. Sound reasonable?
8-100A
- Joel
The balancing powder will not harm the tube. If it did, there is no way they could use it on a commercial truck. When the tire is turning slow enuff for the powder to collect at the bottom, there is no need for balance. When the tire begins to speed up to the point that the imbalance could be felt, the powder is dispersed to the light side of the tire to balance it.
Ask any tire shop that handles heavy truck tires, they will have the scoop on it.
- silverghost
All the beads then drop to the bottom of the tire, or tube.
Then finally when you start-up again the wheels & tires are greatly un-balanced and vibrate until you get up to a good speed again and the beads self re-distribute themselves again.
To me beads are more of an easy "Band-Aid" sort of tire & wheel balance product.
I say~~~Do the job the correct way with wheel weights and be done with it.
Tire Shaver balancer~~~~
Does anyone else here remember those old machines that actually shave off parts of the tire tread rubber in an effort to balance a tire ?
Does anyone use a tire-shave machine to balance old Antique & Classic car tires today ?
A hobby friend still has, and actually still uses his old tire shaver balancer from time to time !
- Mike Dube
mikespeed35 wrote: You are lucky you don't have a L-29. The center hole is too big for most cones used on balancing machines. A truck balancing machine has a big enough cone but the shaft is too short too get a cone on both sides. Jan Appenzeller has a balancing machine with a L-29 hub mounted on it.
Well, the news is all good. The tire shop nearby was able to mount one of my rims on the Hunter 9600, the tech confirmed it is usually used for large trucks. His having to demount a tubed tire to rotate it on the rim for the quick match is not an issue. I have an extra new tube (always carry at least one) just in case. While none of my wheels are perfect, he said the one I bought (by luck) wasn't too bad. He will tell me which are the best (run-out, out of round), and is happy to set the toe in for me. I spent a good bit of time the last couple of days stripping all the tape & crud out of the inside on my rims, will paint them and hopefully get the deal done this week.
Thanks again for all the input.
8-100A
I had bought a special cone for a friends machine to do the 851.
- Mike Dube
This will be the 3rd set of tires on the car during my stewardship. I have used rim bands in the past, and in talking to Universal this time, they recommend rims bands over flaps for my drop center style rims. The bands cover the center section spoke nipples & the tire bead covers those in the outer edge.
I don't have any issues getting them mounted, just not happy with the balancing jobs done previously, especially the last one. This "quick matching" of the tire and rim that the Hunter 9600 spin balancer affords sounds like my best bet.
8-100A
- auburnandyscar
These worked well in our rock crawlers, but they were all tubeless applications.
Check out my build at:
www.1932auburnsedan.com
- silverghost
"] There are testimonials on the Dynabeads site from Model A & T owners, and they use tubed tires. I have posted on a couple of other forums as well, we'll see what develops.
I will be talking to a local shop that has the Hunter 9600 later this week.[/quote]
You have to remember that Ford Model "T" &"A" autos do not travel at very high speeds at all as compared to your Auburn auto.
ALSO~
Most of the owners of these "T" & "A" cars do not drive them very far at all nor~~~ put many miles on them.
They also do not drive much, if at all, on super highways.
- Mike Dube
8-100A
- Mike Dube
www.innovativebalancing.com/index.php
As to spin balancing, if you drive your car, using the Hunter 9600 balancer makes sense. Whatever you think about Corky, you should find this this video on quick matching tires & wheels interesting: In a check of shops in my area, it seems like it's mostly those that handle big trucks that have the 9600, which in itself tells us something.
8-100A
