engine mountings 8-98
- 61xlch
12 Dec 2012 11:33 #24110
by 61xlch
Replied by 61xlch on topic engine mountings 8-98
Thanks for this advise, seems to be the best solution.
But it will take lots of time and shipping costs, because I have to send in the old ones first.
(Anybody of you in the US has an old pair hanging around, which is not needed anymore?) <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
Andreas
Andreas
- Greg Frownfelter
12 Dec 2012 01:54 #24108
by Greg Frownfelter
Replied by Greg Frownfelter on topic motor mounts
I have used the Steele mounts
they are perfect
greg
they are perfect
greg
- C.R.D.
11 Dec 2012 20:59 #24107
by C.R.D.
Replied by C.R.D. on topic engine mountings 8-98
I've never used Steele Rubbers Auburn motor mounts, however I have sent in Buick motor mounts and had Steele revulcanize them and they came back and worked fine. You can check out Steele Rubber's motor mounts at;
secure.steelerubber.com Enter the year and scroll down to American independents and it should come up. I believe the number is: 11-0018-11
Good luck. Carl
Good luck. Carl
- 61xlch
11 Dec 2012 19:21 #24104
by 61xlch
engine mountings 8-98 was created by 61xlch
My engine mountings need to be vulcanized. Its a bunch of work, because I have to make a kind of die / molding.
Possibly there are reproductions available?
<!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: -->
