steering wheel removal
03 Apr 2012 00:39 #22536
by ilikescars
Replied by ilikescars on topic steering wheel removal
Mine came off with some gentle blows on the backside with a rubber mallet.
Also, a friend of mine drilled and tapped some holes in the center hub and used a regular puller on it, as well. No damage done to the steering wheel.
- auburn653
02 Apr 2012 10:45 #22533
by auburn653
steering wheel removal was created by auburn653
I need to remove the steering wheel from 35 Auburn, so I can replace steering box/shaft.
I have removed the Dual Ratio tube, and the steering wheel nut, but can't get wheel loose.
Suggestions? I don't want to damage wheel, so don't want to use a gear puller, and didn't find any internal threaded holes for pulling.
Thanks.
Thanks.
