Oil filler tube
1/16 x 3/4 similar to the glove box strap.red.auburn851 wrote: What kind of lacing?
Marcus
- red.auburn851
Marcus
As to the triangular engine pan on the driver's side by the radiator filler (the 36 s/c Pheaton had both the triangular ones and I bought the other 3 from Curt) someone along the way did something rather unique - they cut the one a touch to clear the spring snubbers and then put the bolt in with put a jam nut on the underside - and then they bolted pans on. The thin jam nut gives the bolt some grip and if you put an "inside" star washer under jam nut you would get even more advantage and I doubt anyone would notice. And, yes I bought a whole set of "N" bolts for their installation - Curt reproduces now.
When I installed the dust pans under my cabriolet, it was done after the engine was in place. I have a feeling that the factory put these in before the engine was dropped onto the frame. My observation: If you need to take the dust pans down for any reason, it's really difficult, because the bolts are installed threaded end down. The bolts spin when you try to remove the nuts, and it's near impossible to reach the bolt heads.
I'm thinking of tack-welding the bolts in place on a different car, just to eliminate that future problem.
Any ideas?
I have a CE4001G coil that is battleship grey (not repainted, original)ilikescars wrote: engine color on the ign. coil? Thought it was black.
There is an old pix of a speedster with a light colored coil. That being said, the coil on my cars are black. But if you see a grey one don't knock him.
As to the Grey engines - they appear done by the service/parts company so I would not put much weight on such either way.
I like the black contrast, but it's prolly wrong...
