Spark and throttle levers of 6-66 AT
- Ivor
10 Mar 2012 00:55 #22372
by Ivor
Replied by Ivor on topic Spark and throttle levers of 6-66 AT
Hi,
To help locate some I suggest you put a request in the forum "Auburn cars and parts" someone might have some or may have made some castings for them by now as I am sure you are not the first person to need them. You can use the photos of mine if you wish. As for the dash, mine is 1 mm (0.040") thick steel over timber and is painted to match body color, I believe this is how they came from the factory.
- the_helmut
09 Mar 2012 16:50 #22371
by the_helmut
Replied by the_helmut on topic Spark and throttle levers of 6-66 AT
Thanks for posting this pictures. Is it possible to get a spare part of this?
On the pictures I can see you got the same dash board like my 6-66. Is it the original color? And what kind of material is it?
- Ivor
08 Mar 2012 05:21 #22369
by Ivor
- Ivor
06 Mar 2012 22:43 #22365
by Ivor
Hi the photo you got from the web is the same as my 1927 8-77 the top lever is the headlights and the two on the left the throttle and advance and retard the horn button is in the middle. I can take some detail photos if it would help you.
- the_helmut
06 Mar 2012 18:53 #22362
by the_helmut
- the_helmut
06 Mar 2012 18:33 #22360
by the_helmut
Spark and throttle levers of 6-66 AT was created by the_helmut
Hi, my Auburn has broken Spark and throttle levers on its steering wheele. I found out. Originally there were other levers on it.
What was he current design? One picture are mine, the other from an auburn from the world wide web.
