How much antifreeze do you use?
- Mike Dube
14 Oct 2010 15:36 #18176
by Mike Dube
8-100A
Replied by Mike Dube on topic How much antifreeze do you use?
I agree with Steve completely, these cars all like to seek their own coolant level. I'm frugal, so while I'll buy premix if need be on the road, I always have an empty a/f jug (or several) around to make my own 50/50. It's probably best if you change it every couple of years.
8-100A
14 Oct 2010 15:24 #18175
by Josh Malks
Replied by Josh Malks on topic How much antifreeze do you use?
There is an important article in Newsletter number 8 about the new anti-freeze formulations. It will be in your hands before the end of this month.
Until you read it, do not put Prestone brand anti-freeze in your Auburn (or Cord or Duesenberg.) No kiddin'.
- sds1861
14 Oct 2010 12:56 #18174
by sds1861
Replied by sds1861 on topic How much antifreeze do you use?
Hello Steve:
You want to end up with a 50/50 mix in the system. Use 50/50 premix or straight antifreeze and distilled water. 50/50 will handle any cold temperatures that Ohio puts out. After you fill it up and drive it for a while, it will probably puke a little coolant out through the overflow tube onto your garage floor. That is normal. Once your car finds the coolant level that it likes, the puking will stop and your level will be correct.
Regards,
Steve Stevens
Regards,
Steve Stevens
- Steve Miller
14 Oct 2010 01:10 #18171
by Steve Miller
How much antifreeze do you use? was created by Steve Miller
It gets pretty cold here in OH, just wondering how much straight AF (not 50/50) do most people run?
