1930 AUBURN 8 125 CAB
- Steve Maggs
14 Jan 2010 21:10 #15560
by Steve Maggs
Replied by Steve Maggs on topic 1930 AUBURN 8 125 CAB
Hi,
I am based in the UK and am looking for a distributor cap and points for an 8-125 cabriolet. Are you able to help or point me in the right direction? Thanks
- JOEL GIVNER
11 Feb 2004 02:24 #1301
by JOEL GIVNER
JEG
Replied by JOEL GIVNER on topic 1930 AUBURN 8 125 CAB
John,
I am surprised that no one has answered your question. Like the Cord L-29, the Big 8 engine has 27 studs. I believe they are 7/16 dia fine thread. The correct torque is 65 - 75 ft lbs wet. Make sure you torque from the center out in a symmetric pattern so as not to apply pressure unevenly to either one side from center.
The distributor per the 8-125 factory parts list is a 657-L and the High compression distributor is a 657-N.
JEG
- JOHN DARRAGH
02 Feb 2004 09:13 #1282
by JOHN DARRAGH
1930 AUBURN 8 125 CAB was created by JOHN DARRAGH
+HELP ME PLEASE
I WOULD LIKE TO TORQUE DOWN THE CYLINDER HEAD OF MY 1930 8-125 LYCOMMING MOTOR FITTED TO MY 1930 AUBURN CABRIOLET IT HAS NOW DONE 300 MILES SINCE THE PREVIOUS OWNER DID THE RECONDITION WHAT FOOT LBS SHOULD I USE ? THANKS JOHN
P.S. THIS CAR HAS A DELCO REMY 657L DISTRIBUTER IS THIS CORRECT? JOHN
