Steering wheel/Horn removal
- mason maynard
05 Feb 2010 03:28 #15782
by mason maynard
Replied by mason maynard on topic horn ring removal
Ken you are right on. the real easy thing to use is a modified oil filter remover.
size it so it wil colapse slightly, then with 2 people,1 holds it down firmly, the other turns.
- Neal Ziff
31 Jan 2010 04:08 #15748
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Replied by Neal Ziff on topic Steering wheel/Horn removal
I attached a pull line to the bottom of the old wire before I removed it. That way I could use the line to pull in the new wire.
Neal
_________________
1930 8-95 Cabriolet
30 Jan 2010 21:51 #15744
by
Replied by on topic horn button
I think you have the same as my 32 8-100A. I believe the horn button unscrews form the steering wheel, I believe then you will be able to see the wire you are talking about. You should then be able to disconnect it from the other end and pull it up through the steer column.
You may need to make a clamp of some nature ( I made a big metal compressible ring ) to loosen mine. lefty loosy-righty tighty
My 2 Cents
K Clark
My 2 Cents
K Clark
- Lance
30 Jan 2010 19:48 #15743
by Lance
Steering wheel/Horn removal was created by Lance
I would like to replace the wire that works the horn . Is there any one who can walk me thru the process for removing the horn assembly and steering wheel ...if needed 1931 8 98A Sedan
Thanks Lance
Thanks Lance
