1936 Cabriolet 852 Winshield question
- mikemcclelland
10 Jun 2009 13:23 #13722
by mikemcclelland
Support the ACD Museum!
Replied by mikemcclelland on topic 36 Cabriolet windshield
Kenny...thanks for the reply. Mike
10 Jun 2009 09:36 #13719
by
Replied by on topic Windshield
There is no secret. It does not come off the car that easy. The procedure is to take the four screw from the top of the windshield. 2 on each side of the top rail, then remove the knurled knob from one side and with a rubber mallot tap the frame away from the glass. it should slide sideways and apart. You may want to have a second person holding the windshield. Because at this point it could fall apart. Putting it back together is the reverse procedure
My 2 cents
K Clark
My 2 cents
K Clark
- mikemcclelland
10 Jun 2009 00:41 #13715
by mikemcclelland
1936 Cabriolet 852 Winshield question was created by mikemcclelland
I need to have glass put in the frame of my 36 Auburn 852 Cabriolet windshield and want to take the frame off the car to take to a glass shop. How do I get it off? Each side has a chrome knob that loosens to allow you to lower the windshield. If I take either or both knobs off the studs that they screw on to will not move...if even just one came out I could easily take the frame off and take to the glass shop. What is the secret? Thanks, Mike
