Radial tires
25 May 2009 04:34 #13592
Replied by mikespeed35 on topic Radial tires
I know of the controversy and made my decision. The decision was based on how I drive my car. I also have radials on two 67 corvettes and a 64 Corvair with wire wheels that were not designed for radials either. They all see much more agresive driving than the Auburn. I will let everyone know if I have any trouble.
24 May 2009 12:46 #13586
Replied by Curt Schulze on topic Radial Tires
Hi Mike, there has been a lot of discussion on other forums and articles in Old Car Weekly about the safety of putting radial tires on rims that were not designed for them. There are engineers that steadfastly disagree with using radial tires on old rims and there are restorers that have used them successfully for tens of thousands of miles.
24 May 2009 05:06 #13583
Hi Curt, I should have said Diamond Back Radials. They are tubless tires. It is recommonded to not use tubes in radials if possible because of the side walls on radials flex making friction against the tubes. There are radial tubes that are thicker than standard tubes if you must use tubes with radials. I chose not to use tubes and have had no problems to this point.
23 May 2009 19:14 #13579
Replied by Curt Schulze on topic Tires
Those Good Year diamond treads are tube type tires arn't they Mike?
I didn't know you could do that.
23 May 2009 04:17 #13576
I used Diamond Back blackwalls with one side shaved of lettering and mounted them tubless. Have driven 3000 miles with no problems and a very smooth ride. I sealed each spoke end with silicone sealer.
- Terry
23 May 2009 00:32 #13574
by Terry
Radial tires was created by Terry
What is your opinion on the best radial tire for our Auburns. 650x16 Terry
