Auburn Electrlock
- DPeeler
10 Feb 2010 20:18 #15860
by DPeeler
David Peeler
1931 Auburn 8-98A Phaeton
Replied by DPeeler on topic Auburn Electrlock
Neal,
I came across the name Frank Cek (216-486-3177) from an earlier posting as someone who does these repairs. I have not tried to contact him. If you do first, please let us know if it proved to be successful.
Thanks!
Thanks!
David Peeler
- Neal Ziff
10 Feb 2010 15:32 #15854
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Replied by Neal Ziff on topic Auburn Electrlock
Hi David,
No, unfortunately I still haven't found anyone. I will probably wind up attempting the dissection myself. In the meantime I've just routed around it with a toggle switch. If you find someone, please let me know.
Neal
Neal
Neal
_________________
1930 8-95 Cabriolet
- DPeeler
10 Feb 2010 14:27 #15851
by DPeeler
David Peeler
Neal - Did you find anyone that rebuilds the ElectroLock?
David Peeler
- Neal Ziff
11 Mar 2009 04:03 #12893
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Replied by Neal Ziff on topic electrolock removal
Hi Chuck,
What a coincidence - I just removed the electrolock from my 8-95 yesterday. It was really simple. Remove the ignition lock cylinder from dash by detaching the grounding wire and removing the lock ring. Pull cylinder back through the firewall. Remove the distributor base with the electrolock attached. Detach the grounding band from the condensor and then carefully remove the attachment nut from inside the distributor and the electrolock is free.
I removed mine because I am having a grounding problem trying to get ignition. I would like to be able to open up the ignition lock cylinder to check out the parts and see if they are intact or if the potmetal has broken up and is possibly one of the parts of the problem I'm having. If you have any info you can share on getting the electrolock rebuilt I would appreciate hearing from you.
Neal Ziff
Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
- auburn895
09 Mar 2009 00:07 #12868
by auburn895
Auburn Electrlock was created by auburn895
What is the process to remove the electrolock from distributor on a 1930 Auburn 8-95 need to send out to have a new lock cylinder made
Thanks in advance
Chuck
Thanks in advance
Chuck
