1935 Auburn "Clementine"
- nklimek
bailout auburn
- nklimek
Is there a cover under the flywheel? If I do get good rotation I will give it a full try- nothing to loose. Men have to see a motor run, it is part of the ritual. All the brakes were full of sludge, but the cylinders cleaned up and held pressure, no pitting inside. I'm hoping that's what the motor is doing but it has to run to really clean out the sludge.
bailout auburn
My 2 More cents
K Clark
- nklimek
I would like it to run, even if poorly it makes it easy to move around. But the front clip is coming off and it looks like a very easy pull anyhow, may as well just pull the motor. I suspect it's an easy build, the head is perfect. I suspect a ring job and bearings might be it. I assume rebuild parts are available, I did an old Plymouth Flathead 6 and it was simple. Even with machining I'm not too concerned.
bailout auburn
I have seen that also' But if you take out the plugs and look at the end you can usually tell if there is something there especially looking into the area that can be seen through the plug hole.
He said it turned over just slowly
My 2 Cents
K Clark
Make sure have gasoline pumping into the carburator
At least drain the oil, refill with new 30w non detergent
pull each spark plug drop in a couple tablespoons of oil
Make sure you have spark at the points
make sure you clean the distributor cap contacts and rotor
make sure have very clean battery connections
make sure you have very good six volt battery ( a bad six or 12 volt will not take a boost from anything)
A BAD CONNECTION WILL MAKE THE CABLES GET HOT AND ALSO THEY MUST BE OF HEAVY GAGE WIRE
( you can put a 12 volt direct in the battery box and it will spin the engine very fast if the starter is any good) BE CAREFUL
( DO NOT turn ON anything other than the ignition switch)
You must remember that you do not know the reason that this car was put away so many years ago. ( it could be the engine)
( BE VERY CAREFUL WITH THE 6 and 12 VOLT BATTERIES THEY CAN
MAKE BIG SPARKS)
For Your Information (FYI)
my 2 cents
K Clark
- nklimek
After much meditation, the motor is coming out anyhow for detail. Even if I can get the gunk, the motor still may need work. Even if it runs, it probably won't be mobile anyhow. Have to disassemble the front clip. Without the motor, car can drag around easy. Since all the bolts turn easy, I suspect it will be an easy pull. The tyranny is tight, no play in the shifter or the rear end but old oil needs to be purged out completely. Then I can get in those tight spots and really check out all the bushings. Looks like disassemble time!
bailout auburn
- Rum-Runner
- nklimek
I left off with seeing it on eBay, but I only wanted to see it. I assumed it was a rusty pile of junk, but the metal was Excellent. Made an offer based on book values but the owner was quite disappointed- figured he had a ca brio. Nevertheless, After the toughest pull I ever had, it's sitting at my undisclosed location safely hidden from the wife. Simply the coolest 4 door sedan styling I have ever seen, bone stock you just want to go rob some banks. Latest updates, It has brakes and we have spark, just need some time to finally crank it up. The upholstery is being reproduced. Did have to slap 4 wrangler radials on it to wheel it around. Just too burned out for a frame off, but I really don't think it needs it. Every bolt turns- it's really just a dent job. Many parts did walk off, but most of it is there.
got brake lines from Wisconsin, club member has both the parts and the experience so I think this puppy can be done correct. The brake drums and shoes were like new, just seals and a clean out and the brake system works great. I am pretty sure they were never done and I'm pretty sure this is a low mileage car. Unless the motor has internal issues (old rusted rings and bearings) I might even run it without an overhaul. Someone did pop a newer crab on it and rebuild the starter 10 or so years ago and got it running. Also fount an NOS wire harness from a 30's Ford. Should have enough wire to duplicate the harness. I like top post pictures, this forum is a little tough but manageable posting pictures. Hopefully there are car nuts out there that find this interesting!
bailout auburn
- nklimek
Wild Hogs, the movie was filmed there, it was the biker bar. I could probably get it on the road quick but time runs short. I did find a club member in Wisconsin with most of the parts I'm missing, I got the brake lines and a few things from him already. I tend to drag cars home faster than I finish them!
bailout auburn
- nklimek
Had this car any rust, I would dump it. Normally you find lots of bad surprises as you tear into them. This car has been all good surprises, there is simply no rust. Even all the bolts turn easy. It's odd getting a car this old without rust, but it saves 90% of the hassles. I'll be posting more as I get into it.
bailout auburn
You will have to get rid of that "radio delete" and install a nice Crosley radio when you get around to it! Good luck with the resto!
- kbenefie
- kbenefie
- Justin Kerns
- Thank you received: 8
My email is justin.kerns "at" att.net
Justin
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
- nklimek
The car was on eBay near Santa Fe. I was only mildly interested, but when I looked it over it's hard to pass up a rust free car, especially that old.
bailout auburn
- Justin Kerns
Justin
- nklimek
bailout auburn
- nklimek
bailout auburn
- Greg Frownfelter
looks like you got a very nice start
greg
- nklimek
Well, Clementine turned out to be a 1935. Some very nice bones. The upholstery is interesting, definitely original but perhaps not salvageable. The seat bottoms are good, but tear easily. No rust in the frames.
The motor turns with compression and no funny noises, so I believe we are ready to start this weekend. I hit the starter, it spun but the gear didn't engage the flywheel, so I've got to go in. Hopefully it's just a stuck Bendix. The e-brake cable broke, so I may rig a cable until I can get the original cables reworked. So, It will be interesting if it runs!
bailout auburn
