36 Auburn
- nklimek
bailout auburn
- nklimek
- nklimek
Wow, under the denim covers, we actually have some pretty good back seats!
bailout auburn
- Mike Dube
Our old buddy Joel has (had?) the Wild Woodpecker logo on the flanks of his 12 cabriolet a few years ago. Kinda hope it's still there.
8-100A
- nklimek
The next nice stretch of weather, I will gut the interior and power wash everything. I'm going to leave it all pretty much as is. No 350 Chevy, spinny rims or mustang 2 front end. No chop top, shaved handles and velor seats. No DVD and a huge base speaker for the trunk. No flames, electric windows or a 411 rear end. no candy finish on a fluorescent paint job. no decking, Frenching or 34 Ford grill.
I hope I'm not disappointing anyone.
bailout auburn
These and many other running changes were made through the end of production. None were all done at once.
- auburn653
I was going on the "LYCOMING" on the side of the block. My 35 does not have that, and has the water jacket cover (WF-3923).
I don't have the info here right in front of me, but someplace I have the WF number that marks the change from Carter to Stromberg carb, valve timing changed, and I also assumed that was when the block was changed to the freeze plugs.
Does anyone know if this is the case? Or, when the engines changed from water jacket cover to freeze plugs?
- nklimek
frame 2027
engine WF5066
starter MAJ1033
generator CAR4603-3
Well, it will be interesting to see what it is.
nothing under the back seat except a 1963 classics illustrated comic book
"the red badge of courage" and a lot of dust! still too cold for the power washer and I'll want it to be over 60 and some brakes before I try the start-up. Hoping to find a stack of silver certificates, but it was the depression after all. Neat how the seat folds up to expose a trunk. All the old upholstery is still there, but it is pretty tattered, but it might make some good swatches to duplicate the material.
bailout auburn
- nklimek
bailout auburn
- auburn653
- nklimek
bailout auburn
- auburn653
Engine number is located on top deck, right behind the heat shield on drivers side. Should be WF.... May also be stamped on the engine plate.
Frame number is on passenger side, right in front of the fender support rod. Don't clean too hard, numbers are VERY light.
How about headlight pictures. From earlier pic, it looked like early 35 style that fit down in fender. Late 35-36 mount on stands.
- nklimek
left side of motor
right side of motor
the old cracking lacquer paint
dumped a quart of oil down the plug holes. It was started 10 years ago, looks like new autolite plugs, wires, points cap and rotor. The wal mart breather cap and the clean starter from a rebuild. I'm optimistic that it just might go. Believe I'll lube the distributor, all the old oil was drained. Let me know if that's the 35 motor!
bailout auburn
- Ohio AMX
nklimek wrote: I was kidding about rodding it-
I knew you were just messin' with us! <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
Scott Campbell
Medina, OH
- nklimek
bailout auburn
- auburn653
Do you have a photo of the passenger side of engine? Does it have a rectangular water jacket plate? If so, then it's a '35.
- nklimek
bailout auburn
- Ohio AMX
I would fix what needs fixed and leave the rest alone. You can always restore it down the road. There are already too many street rods of every make. If you make it into a rod nobody will even care that it was an Auburn.
Scott Campbell
Medina, OH
- nklimek
OOps- sorry for the big photo. you can see alot of old fabric still there, they just made denim covers that come right off. Fortunately they didn't rip out the old material. I had to pop on some wrangler radials, I have some ideas-
perhaps a rock crawler? with a baby hemi and those spinny rims. Better yet, a small block Chevy. Has anyone chopped the top of one? I just can't find any of these rodded on the Internet. thousands of big three hot rods, yet no auburns?
bailout auburn
- nklimek
Now I believe I can tap out a few dents and polish, making the car look better without major paint and body. issue one, do I clear coat it to encapsulate the old paint? I have seen that done. Most dents look like they will somewhat tap out, I assume no fillers, leaving some visible dents.
But the bigger issue is the interior. The original fabric still hangs in shreds, although at some point someone had made some denim covers. no foam, it's like sitting on a cotton bail but still comfortable. Should I have the interior redone or leave it hanging, perhaps recover the areas missing fabric with something similar? Most "soft" components just have to be replaced. Perhaps a cloth cover protecting what is left? Unrestored original is a tricky area, as you have to define maintenance vs restoration and there is alot of grey area.
On the final note, I will attempt the start up soon. Apparently it started 10 years ago and they had rebuilt the starter. I would love to not rebuild the engine, but realistically that might not happen. if I do bearings and valves, can I still call it unrestored? The shifter is tight and the Columbia is smooth, I suspect no tyranny or rear end problems.
bailout auburn
- Rum-Runner
Bob
- Rum-Runner
Bob
- nklimek
Brake lines, cylinder rebuild kits
hood ornament
correct wheels (these were old tube wheels, was there a hubcap?)
couple of outer door handles
glass for headlights and taillights and instruments
rear tire mount
Air maze inlet filter
windows
Over the years, vandals broke out all the glass and pulled off the speedo needle. I suspect these are not too difficult of items to find. A nice fellow in Wisconsin has a barn full of parts, I suspect sedan parts are easy to find. The up side to an unresored original is it doesn't cost much and I may be able to prepare it for Oklahoma in April.
bailout auburn
Is that the original paint?? Good prospect for "survivor" class.
- nklimek
I'm taking a stab at posting photos
Got the car, the bolts do turn free
Other than the red dirt, this is a true time capsule. The 18K miles are probably correct, this car was driven a few years and in dry storage ever since. Don't need WD40, no rusted fasteners. Even the brake drums are good, barely worn. Yes, the soft components and upholstery are not usable, but still good for patterns. The wood floors are still strong. I can't believe there is a rust free original car from the 30's, but this is it!
bailout auburn
- nklimek
I do want to track down the history of the car. The body tag is gone, but it looks like I may be able to get a number off the frame. Looks like it needs a rear bumper, hubcaps and a hood ornament, but otherwise it appears to be mostly complete. once I get it back, I may try to keep it as an unrested original if I can get the 6 running. Granted, you always find surprises lurking in the bowls once you get it home. I'll take it to Denver for a going over, then take it from there. How do you post pictures on this forum?
bailout auburn
