Flywheel 1931 8 98a
- Greg Frownfelter
24 Sep 2008 23:56 #11440
by Greg Frownfelter
Replied by Greg Frownfelter on topic Flywheel 1931 8 98a
the flywheel can be repaired
project requires lathe work and replacement gear
I also have a good used one if you need
greg
greg
- JNORCIA
24 Sep 2008 01:50 #11428
by JNORCIA
Replied by JNORCIA on topic Flywheel 1931 8 98a
Did you find a flywheel ?
- JOEL GIVNER
13 Aug 2008 11:07 #11017
by JOEL GIVNER
- Lance
13 Aug 2008 00:30 #11009
by Lance
Flywheel 1931 8 98a was created by Lance
Does any one have any leads on a good used flywheel? My engine is now out of the car . We noticed that the teeth on the flywheel are pretty chewed up . Anyone? Lance 1931 8 98A Sedan....now located in two different buildings
