REAR WHEEL STUCK/INSTRUMENT PANELS/BEZELS/HUBCAPS/OPEN BODY
- Bruce Beattie
22 Jan 2008 08:35 #9265
by Bruce Beattie
Replied by Bruce Beattie on topic REPRODUCTIONS
HI PHIL,
THE OTHER WEB SITE YOU SHOULD TRY IS:
www.vintageandclassicreproductions.com/
REGARDS,
BRUCE BEATTIE.
BRISBANE. AUSTRALIA.
REGARDS,
BRUCE BEATTIE.
- Terry
21 Jan 2008 17:04 #9263
by Terry
Replied by Terry on topic Hub Caps
Get in touch with
Bob Ballantyne 24 Valley View Road Glenfield,North Shore City. New Zealand. Ph No. is 649-444-4066 his Fax is 649-444-0060. This was a good name and number in 2001 so give him a try and let all know if he is still making the Auburn hub caps. Good luck.
- Terry
21 Jan 2008 16:54 #9262
by Terry
Replied by Terry on topic rear wheel stuck
It is highly unlikely that you have a problem in the differential or axle shaft bearings.
I would raise the rear wheel that is sticking and release the brake shoes with the brake adjuster toll.
Next I would gently tap around the drum to release the sticking shoes, also tap on outer edge of drum from the side.
This should do the trick for you.
Good luck
Good luck
- cpkphil
20 Jan 2008 13:13 #9253
by cpkphil
Thanx & regardz, Phil Giacomantonio
Like your music raw & retro?
Go to Vjingle.com and enter
Butch Philips in artist search.
REAR WHEEL STUCK/INSTRUMENT PANELS/BEZELS/HUBCAPS/OPEN BODY was created by cpkphil
Hi! I have a 1935 653 and the rear driver wheel seems to be stuck. Would that more likely be the brakes getting rusted in, or a rear end problem ( I have a 2 speed)? Also anyone have a line on instrument panels and bezels?? Lastly, I was told somone in Australia makes repro hubcaps.....anyone have a name or link? I still need a rear wheel cover (or at least the tread cover) and an open body. Thanx, Phil Giacomantonio
