Problem with charging system
21 Jan 2008 16:34 #9261
by ilikescars
Replied by ilikescars on topic Cut-out
More information I found out about the Cut-out: Another name for this device is "Reverse Current Relay". It's job is to prevent the battery from "motoring" the generator after the car is shut off. It is NOT a voltage regulator. You can regulate your voltage by manipulating the third brush on the generator.
20 Jan 2008 19:26 #9258
by ilikescars
Replied by ilikescars on topic Problem with charging system
Terry, Murray & Pete: Thanks for the input! I cleaned up my contacts under the dash at the ammeter and tightened them real good, but no dice. I finally installed a different cut-out that I had bought thru Ebay and that did the trick (so far). That's my third cut-out, so I hope she holds up.
By the way, I was told by a "grizzled old Auburn Expert" that polarizing is never needed with a cut-out system. Only with more modern voltage regulators.
Mark <!-- s:idea: --><img src="{SMILIES_PATH}/icon_idea.gif" alt=":idea:" title="Idea" /><!-- s:idea: -->
- Murray Hall
20 Jan 2008 03:28 #9247
by Murray Hall
Replied by Murray Hall on topic Auburn Charging System
I talked to a friend of mine who is an expert at solving electrical problems.
He, too, said to make sure that the connections on the amp meter are tight. Also, check for any warm connections with it charging. Is the fan belt tight? With the car running, at a medium engine speed, check the DC voltage at the generator side of the cut-out. If it is 7 volts or more, check the output voltage on the battery side of the cutout. The DC voltage should be the same on both sides. If not, the problem is in the generator. Hope that this helps you.
Murray
Murray
19 Jan 2008 18:14 #9241
by
Replied by on topic intermittent charging
Check the connections ie on amp meter
19 Jan 2008 17:59 #9240
by ilikescars
Thanks. I did try to polarize the generator by touching a wire to the "Field" and then to the "Batt". I got a good spark, but when I started the car and revved it up, still no charge. Maybe I'll try a different cutout...
- Terry
19 Jan 2008 16:31 #9239
by Terry
Replied by Terry on topic generator
- Terry
19 Jan 2008 16:26 #9238
by Terry
Replied by Terry on topic Generator
You must polarize the generator every time it is disconnected or serviced.
To polarize the generator, simply make a short jumper wire to short between the battery (b or bat) and generator (g or gen) lugs on the cutout relay or voltage regulator. Only a split-second or a spark is required, so simply tap your jumper wire onto the lugs and pull them right back off.This should cure the problem
19 Jan 2008 14:23 #9236
by ilikescars
Problem with charging system was created by ilikescars
Hi: I'm wondering if anybody can help me with my charging system.
I have a 36 s/c Auburn with a six volt generator. When I first installed it on the car, the ammeter indicated no charge. An hour later I ran the car and it was charging perfectly. The next time I ran it, no charge. I changed the cut-out regulator with a new one, but still no charge. I took the generator off and had it tested at a automotive shop, and it indicated that it was working fine. When I reinstalled the generator and started the engine, it showed a charge again. Then the next day, no charge. I cleaned the points on the cut-out. Same results. It's driving me nuts.
BTW, I made sure the generator was properly grounded to the engine.
Any help would be appreciated.
