1935 Sedan floor construction
01 Dec 2007 13:23 #8818
Replied by Curt Schulze on topic Floor boards
The front floor boards are comprised of six different pieces of 5/8 inch plywood, with 1 x 2 on the underside at the seams where the plywood join together. The transmission cover is stamped sheet metal. The center section of the floorboards are 5/8 plywood on both sides. The battery box cover is formed composite material. The rear is all sheet metal with the exception of the seat pan cover which is convertible top material.
If you need more help with this, give me a call I'll discuss it in more detail.
Curt 715-262-3183. <a href="mailto:[email protected]][email protected][/url]
- red.auburn851
30 Nov 2007 21:51 #8817
by red.auburn851
1935 Sedan floor construction was created by red.auburn851
Does anyone know how the original floor was constructed. I am restoring a car and noticed the floor is currently plywood. Was the original floor steel or wood?
Marcus
Marcus
