Head gaskets keep blowing on 851
- cbsIII
"I work for the Auburn Automobile Company. I am not an automobile race car driver although I hold more world speed records than any other man in the world" -Ab Jenkins 1937
- JOEL GIVNER
KNOWING JOHN FOR YEARS, HE IS REPUTABLE AND IF HE DID SOMETHING WRONG, HE WOULD MAKE IT RIGHT. I AM QUITE SURPRISED THAT HE WOULD "SLAP" SOMETHING TOGETHER. HIS REPUTATION IS IMPECCABLE. I WILL FORWARD HIM YOUR COMMENTS.
JEG
My own opinion is that the head might be warped, which is alot easier to fix than an engine block. But I'm no expert.
BTW, Forsyth rebuilt my engine, and I have since found some half-baked shortcuts that he took in the process. One of the shortcuts was a slapped-together supercharger, which cost me $$ to have redone.
- JJINWI
Jim Nicholson ACD CLub member since August
Tom
- red.auburn851
GIVNER wrote: Red Auburn:
Apparently you are not learning from the previous owner. Trying to manually flatten the block is absurd. This needs to be done properly by a machine shop. The motor must come out and be decked properly. The guru of all guru's is John Forsythe in Fremont, Ohio. But let me also say that any good quality engine rebuilder can rebuild these engines. There is no mystery in these Lycoming 8 cylinder engines. As far as the problems with the head bolts, again, a good engine rebuilder can evaluate and tell you whether the block is beyond repair or not. Crucial to any machining when trying to straighten the head bolt problem is whether there is enough material to work with so as not to break into the water passages.
Thank you for the advice Joel.
- JOEL GIVNER
JEG
- red.auburn851
ilikescars wrote: Where do you live? I can recommend a re-builder in the Chicago area, or I can present your question to him and get back to you. He's a Lycoming guru.
The problem I have is a block that is not flat or warped. It is at the shop right now. The former owner kept replacing head gaskets until the bolt holes were all striped. The wholes were heli-coiled but the drilling was not straight. So we are drilling the holes to 9/16 and using inserts to straighten up the bolt holes in the block. I understand that the block may not have to be decked if we can file it flat enough. I am trying to avoid pulling the engine at this time. My friends say we should be able to file it down to get within 6 to 10 mills of flatness, then use a pair of gaskets to cure the problem. I would like to know if this is true. The car is currently with Bruce at Classic & Exotics, a very good restorer in the Detroit area. I had it in to fix the brakes, but the car blew a head gasket on the test drive. I suspect the nuts were loose on the head, this combined with the warped block caused the head gasket to blow. Other problems were discovered after that.
Many thanks,
- JJINWI
Thanks. Jim Nicholson north of Milwaukee
- red.auburn851
What solutions have people found to fix this? Is the only way to machine the block or is there some other solution? Is this a good time to go ahead and rebuild the engine or buy another engine? Who rebuilds this type of thing?
Marcus
