lubricant level in 2 speed read end?
- Joel
25 Apr 2007 15:56 #6912
by Joel
Replied by Joel on topic lubricant level in 2 speed read end?
Thanks!
- sds1861
24 Apr 2007 23:23 #6907
by sds1861
Replied by sds1861 on topic lubricant level in 2 speed read end?
Joel:
Yes, that is the filler plug. It seems to be low on the unit, but the ring gear picks up the lubricant and slings it around inside the housing.
regards,
Steve Stevens
regards,
Steve Stevens
- Joel
24 Apr 2007 21:47 #6906
by Joel
lubricant level in 2 speed read end? was created by Joel
On a 33 Auburn 2 speed rear end, is the small plug on the back cover, well below the axle centerline, the level indicator plug?
Thanks, Joel
Thanks, Joel
