Radiator boils over
- Hank Reus
- Steve Miller
AuburnAutoCo wrote: 31-33's are supposed to have a water distribution "plate" ( about 1/4" high, with various size holes in it) welded onto the back of the side inspection cover (plate on generator side of engine held on with 32+ screws). These have all but rusted away over the years due to corrosion inside the engines.
After fighting overheating issues for a few years, including radiator recore, block flushing, re-ringing engine, rebuild waterpump, etc., etc., putting the water distribution "plate" on finally solved the problem.
This was printed in the club newsletter last year, with a dimensional drawing of the plate. Made up a new cover with the distribution plate on the back. Hole sizes get smaller the closer to the water inlet. Same piece was used on L-29 engines as well.
I have tried to find the article from 2005 regarding this plate and have had no luck. Anybody know which article this was in?
- lloyd riggs
- michael arata
- Kees Richie
Could you post in which number this article about the Water
Distribution Plate was published?
8 cylinder nut
- AuburnAutoCo
- Mike Dube
8-100A
- jrbartlett
- mason maynard
- Kees Richie
No more overflow whilst running since then. Be sure to have long hose connected to your overflow outlet.
At speeds between 55 to 60 MPH, and the head temp at 180-190, the water temp at inlet radiator is 210. Believe me, I installed new calibrated dash temp gauge and additional at rad. inlet.
8 cylinder nut
- Mike Dube
When I pulled the head for a valve job at the end of the 6th season, I found I did not have any thermostat, nor was there any type of flow restrictor. I agonized over the thermostat for a while, but in the end put it back together the way I found it, except for a Gano filter in the upper hose to catch debris. I suppose this restricts flow in a limited way. We are in our 9th year together now, the temperature still runs the same 175-185 degrees it always has, and I quit worrying about it some time ago.
A good friend, who may weigh in here at some point, has tried everything, and I mean everything! Even tho his old rad had been cleaned and flowed pretty well, and after trying everything else 2 or 3 times, he eventually put in a new core. His car still runs hotter than he'd like. John Forsythe once told us, that in his experience, some of these engines just seem to run hotter than others for some inexplicable reason.
So, is the advise about the thermostat good? Yes it is. Am I going to put one in my car? No I am not.
There you have it Mike.
8-100A
- michael arata
