898 Hood Alignment
29 Aug 2021 14:41 #43822
Replied by Curt Schulze on topic 898 Hood Alignment
You have one adjustment and that is the rad shell.
- CTCraig
29 Aug 2021 13:48 - 29 Aug 2021 13:50 #43821
by CTCraig
898 Hood Alignment was created by CTCraig
The hood fits great around the cowl and radiator shell. BUT the gaps on the sides are off. Drivers side: big gap at the cowl. Passenger side = none. It's as though the radiator needs to be moved over. There is slight difference in the gap between the headlights and shell but not much. So, what's the best way to fix this? Tilt the radiator assembly? If I move that front hinge, I'm afraid it will throw off the fit at the curves. Thanks!
Last edit: 29 Aug 2021 13:50 by CTCraig.
