8/10 Vapor Lock
- pneflyer
Topic Author
- ACD Club Member
08 Jul 2019 13:28 #37705
by pneflyer
Replied by pneflyer on topic 8/10 Vapor Lock
Replaced
- ACD Club Member
- Thank you received: 106
08 Jul 2019 14:34 #37706
Replied by 1748 S on topic 8/10 Vapor Lock
Have you noticed the engine running hotter than normal? I know its air cooled but sometimes the belt will loosen up.Then it slips so the fan is not pulling all the air for cooling. The design on this belt is very suspect.It is not running "normally thru the pulleys. It has to twist coming off the crank at the change of direction before it reaches the fan on top of the flat 6 engines. Might even change the belt just because it may not have been changed in a long time. V belts can look fine but are well worn out.
Time to create page: 0.112 seconds
