Transmission Fluid and gage on pump
I would be interested in finding out about oil cooler modifications.
I am restoring mine to be a good reliable driver. I am located in Australia.
My email address is [email protected]
- rlwardne
If you haven’t you should as there is no visual way to check it.
- rlwardne
I did purchase the pump from the fellow on eBay mainly cause he only lives three hours away. Installed and test run on stands in second gear produced 15 psi at idle speed. Now to fix the leak on my filter housing. Pretty sure the fluid I’m running is more summer driving. Is the Gibbs yellow metal safe.? I haven’t looked
At their data.
- Cordura
Gary Parsons.
- rlwardne
- rlwardne
- rlwardne
Randy
- rlwardne
Out the output on the case. Replaced the spring and ball and decided to run some more never eeked a drop. So guessing the pump is pooped? Can I guy remove that pump while in the frame?
Thanks Jim!
- rlwardne
sucking from the case to the pump as I understand it.
Randy
- rlwardne
Thanks Randy
As for the gauge it's very simple to add one in. you can pull the plug in the cap on the filter and tap a line for a pressure gage or put a pressure switch in there with a light on the dash or in the glove box.
- rlwardne
In to check the health of the transmission pump?
