- Thank you received: 10
- RubyDS
- RubyDS
- RubyDS
- kevin69
- Banned
- RubyDS
Yes a little modernizing on the bearing,impatient to hear the first start.
- RubyDS
News valves
New shell for the crankshaft...................................... Deutz tractor
New shell for the rod........................................Peugeot,French part in American engine,Cord is international!!
New shell for the camshaft.........................home made
- RubyDS
- RubyDS
- RubyDS
- RubyDS
Frank
- RubyDS
- RubyDS
- RubyDS
- RubyDS
Frank
- RubyDS
- RubyDS
Those wheel opening patches are tricky to get right.
I find that rounding off the corners on patch panels minimizes warpage.
Keep the pictures coming
Frank
- RubyDS
Now I have to remake the exhausts holes in the wings, a club member would have a drawing to make the bezel <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: -->
And what is the diameter of the exhaust cover <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: -->
- RubyDS
- RubyDS
Yes the car was fitted with a supercharged fence by previous owner, I do not have the standard fence so I'll leave it with the supercharged fence and exterior pipes but without supercharger on my engine.
You are doing a great job on the restoration. I look forward to seeing what you have accomplished each time I get on my computer.
- Red Brick
Albert
- RubyDS
- RubyDS
The price includes sales tax so the pair of heads costs $2580.00. The tax takes the cost to the @2800.00 amount.
- RubyDS
I will study the club newsletters to see who sell this cylinder heads.
If you have some links i'm interested.
My heads are great. I have had no trouble with them. While you have the engine available I would clean up the intake and exhaust ports by grinding off bumps and smoothing out all the ports. You can also match the manifolds to the block to make a smoother transition. This is called porting here in the USA and can make a better running engine which I believe mine is.
- RubyDS
Re-borred + 0,60
The block is in good condition but the cylinder heads bought with the car are in very bad condition,corroded and cracked.
Where can i buy new cylinder head at correct price?
- RubyDS
Tig welding on corroded aluminium is funny,yes <!-- s:? --><img src="{SMILIES_PATH}/icon_confused.gif" alt="" title="Confused" /><!-- s:? --> very hard to do a beautifull welding and aluminium welding is not my speciality.
I still have a lot of work to adjust the headlights cover.
Tig welding old corroded Aluminium is fun right?
Be sure to get those headlight openings spot on and checked with covers working. It will save you a lot of swearing when the car comes together.
Frank
- RubyDS
- RubyDS
To change of this horrible actuality go to the garage with my son.
English wheel
And a drawing by my son with text in english for American friends.
- RubyDS
- RubyDS
- RubyDS
- RubyDS
- RubyDS
- RubyDS
1748 S wrote: Can you tell me where you purchased the camshaft bearings? I need a set. Thanks
I do not know yet what I will use bearings for the camshaft, I would tell you shortly <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
- RubyDS
On the engine,re-bore +0,60,new valves ,all the crankshaft on news shells and new camshaft bearings
- RubyDS
