- Thank you received: 7
Need motor block
- pfree3233
12 May 2023 03:07 #47180
by pfree3233
Replied by pfree3233 on topic Need motor block
Hi, I know of a motor from a 29 speedster that is available. Please contact me for information. Thanks Pat
616 863 9932
[email protected]
616 863 9932
[email protected]
31 Mar 2023 22:19 #47044
Replied by mikespeed35 on topic Need motor block
Try calling Jay Lawson at 269-217-2604. He has a Auburn block, but he is unsure what year it is.
26 Mar 2023 21:57 #47030
Valve seat though. Can't imagine JB weld holding up to compression heat.
24 Mar 2023 14:45 #47003
by ilikescars
Replied by ilikescars on topic Need motor block
I was able to repair a Model T block with JB Weld a number of years ago. Still works fine. The key is to blast the area first and grind the crack a little before applying.
- Pat Leahy
- Thank you received: 27
16 Mar 2023 23:29 #46965
by Pat Leahy
Pat Leahy
Replied by Pat Leahy on topic Need motor block
C&P Machine does Lock Stitch work on a regular basis, so I assume it was not feasible. Maybe it's not recommended at a valve seat. I have successfully welded a number of Cord blocks. My son Joe has over 5000 miles on his Westchester with large cast iron panels on each side, just like Josh Malks car done by Bill Bicknell.
Pat Leahy
The following user(s) said Thank You: danc2003
- compressor guy
15 Mar 2023 19:18 #46960
by compressor guy
Replied by compressor guy on topic Need motor block
Dans2003
I would reccomend looking at a Cold Metal Repair--Metal Stitch Repair
In my business of repairing Old Cast Iron Reciprocating Compressors up to 1000 hp we were never able to weld old cast Iron -- Just did a Repair on a high pressure 750 psi by the Lock Stich method
I know a lot of old blocks that have been scraped because of poor casting from the 30s
- compressor guy
15 Mar 2023 19:18 #46959
by compressor guy
Dans2003
- danc2003
09 Mar 2023 12:55 #46919
by danc2003
Replied by danc2003 on topic Need motor block
Cracked in valve seat going down cylinder wall. Take it to c and p machine to get it looked at and was told to try to find a block. To me doesn’t look that bad can’t see the crack showed up on magna flux. Thanks
09 Mar 2023 06:45 - 09 Mar 2023 06:47 #46918
Replied by Terry Cockerell on topic Need motor block
Where is the crack and how bad is it?
It could possibly be welded.
Contact Bill Bicknell in Missouri, he had broken panels in Moonshadow's engine repaired by welding in new cast iron panels.
Last edit: 09 Mar 2023 06:47 by Terry Cockerell. Reason: Adding pictures
- danc2003
08 Mar 2023 16:58 #46916
by danc2003
Need motor block was created by danc2003
Found out today motor in my 31 auburn has a crack in it. Does anyone have a 8 cyl block available? Appreciate any help thank.
