- Thank you received: 135
New Interior for 851/2 replica
- AuburnNut
Topic Author
In this section I will discuss the Dashboard layout and Instrumentation. I will show the original design and then discuss alternatives for Replica car owners. Most of our replicas were built in the 1970’s and 1980’s, when the choice of instrumentation was pretty basic. The aftermarket industry today is much greater than it was back then. Many replica cars have various types of gauges used but I note many had basic Stewart Warner gauges but there are a whole range of other providers that were used. In my case, my car was equipped with AutoMeter gauges. The thing to remember with gauges is that the sensors must match the calibration of the gauges. If you change your gauges you may need to change other aspects of your car to ensure the gauges work properly. Let’s start by looking at an original interior in the photo below.
Note the following info relating to the original....
1) there are 2 large gauges in the panel in front of the driver and one smaller gauge. The photo shows what each gauge does. Each large gauge (on drivers side) is 4 & 5/8 inches in diameter while the smaller middle gauge is 2 & 7/8 Inches in diameter. These dimensions are important if you are trying to replicate the layout of the original, even if you are using alternative instruments. You may find it difficult to match the exact size of these instruments with alternatives in the aftermarket industry. There are however sizes that are close as you can find many instruments that are 4 & 3/8 inch diameter (little smaller) and many instruments that are 2 & 5/8 inches
2) there are either 1 or 2 gauges in the panel in front of the passenger. One for a radio (if fitted) and the other for a clock. All Speedsters had clocks, but I understand the radio was an option. All original gauges were actually made by Stewart Warner (except the clock), although there is no labeling on the instrument faces. These gauges are unique to Auburn. They come up for sale occasionally so are therefore difficult to acquire in a hurry.....you will need to scour Ebay etc and collect them over the months/years.
The size of the clock is 2 & 7/8 Inches in diameter and the size of the radio is ??????? Inches in diameter
3) note the 3 knobs and one Toggle switch surrounds the tachometer on the driver side. The Choke knob obviously is not required on most replicas because most of our engines have automatic chokes rather than manual chokes. The Gas knob essentially is an idle control (to freeze revs at a certain level) which once again is not required on a replica, while the Light Knob obviously controls the Headlights. The chrome Toggle switch controls the fog lights if you have them. There are many ways you could wire your ighting on your car, so this is an area where you could repurpose these switches to control what is relevant to your replica. If you are using an original instrument background panel (metal plate with stripes), you can use the area designated for these 4 switches as switches, or you can place small turn signal lights, high beam lights, or a combination of switches and lights.
4) note that the background panel (Dash Insert) which surrounds the instruments (and has the stripes going along it) were previously available new - but now no longer. Good luck trying to buy them. If you do manage to get hold of some, be aware that you should try and get matching sized instruments so as to match the pre-cut holes for the instruments. Alternatively, you may need to buy some engine turned aluminum and cut out holes to match instrument size.
Regards Jerome
TBC
- Thank you received: 190
- AuburnNut
Topic Author
The black interior you have done certainly looks magnificent and is the first and only interior door card and seat that looks completely authentic to me. I’m sure there are others but no doubt it’s rare. What a wonderful reference photo.
Thankyou for confirming there are 13 panels in the original design of the seat. It is difficult to see in the earlier grey looking original interior because the photo is taken from the side. So 13 panels it is. For replicas, it may depend how wide their seat is as to how 13 panels look. They may have to compromise as I have done.
Your photos provide an additional reference point for interior door handle placement. I can see that they point downward at approximately a 45 degree angle. Interior door handles in replicas will of course vary in style to the original shown here. In fact I picked handles from an early ford Victoria, which I thought was a sympathetic design to the original. These ford style handles have a square shaft rather than a spline so the position of the handle is dictated by that and is far less adjustable than a spline. I’m not sure whether the original Auburn door interior door handle has a spline
I also note the pattern in the leather coloring. I was not aware that Auburn Leather was handpainted to give a mottled look. I have spent many years Restoring Rolls-Royce and Bentley interiors and they never used a mottled paint finish....so I am learning something new. For example a mid 1930’s Bentley is known as a Derby Bentley. Their Leather was a uniform color but had a wash of black leather color which was wiped on top of the main color and then immediately washed off so that it was retained within the natural leather grain low points. Connolly leather referred to that finish as Luxan.
Regards Jerome
pattern in the leather. it was no small task to reproduce that.
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
This second design, with flat panels of leather, was a technique that was used among fine coach builders around the world. In fact, I owned a Bentley with the same design. One of the reasons the style became out of favor was the expense in creating the seat. A large flat panel of leather requires a large high quality hide. It is often difficult to get large pieces of leather without flaws....and there is a lot of wastage.....this is ultimately why pleats became a more practical alternative for car builders.
It really is a personal preference as to what you like. I prefer the pleated seats (marginally) over the plain design
Regards Jerome
- AuburnNut
Topic Author
- AuburnNut
Topic Author
Attached is a photo of the car seat I have just built. It is once again very sympathetic to the original car seat design, but does differ a little due to practical issues and personal preferences. I will discuss the differences shortly. I should say, this car seat is based on a Ford car bench seat which has been shortened to fit the cabin of a Speedster. I did not do that, but the manufacturer Elegant Motors did. I could tell it was a shortened seat because of the weld marks on the frame once I pulled the seat apart. This particular seat is on tracks, which allow you to move the seat forward or backwards by lifting a lever on the side of the seat. The seat also tilts forward by moving another lever on the side of the back cushion which is useful to access the storage area behind the seat. Both features are desirable and practical. I do not know what functionality the original seats had in terms of moving them forward and backwards, or tilting the back cushion forward.....(Note: Mike in a later post tell us the original car does not have the ability to move the seat forward or backwards, and the original seat does not tilt either)
Regards Jerome
- AuburnNut
Topic Author
That’s very interesting, and it’s great to have a guy like yourself contribute to this discussion.. I think I will have a separate posting on wheels for replicas, and we can consider different styles and approaches in that. I’m sure you will have plenty to contribute. What I am hoping to do is to create an archive of sorts for replica owners to be educated on originality of various features of the car’s, and then to consider whether they want to retrofit original equipment (which I think is always desirable if you can afford it and if it’s available) or a suitably sympathetic alternative. I think I’d like to keep each Topic Thread on this website on point, and not depart from the topic in discussion. That way it becomes a concise reference point for others. This topic is 35/36 interiors, so I’d like to continue on that, and suggest I now post some information on the car seat.
I really wanted to write a series of articles in the ACD magazine, but after correspondence with our current ACD President, and the President before that, it appears the ACD magazine only discusses articles on original car’s......I think a very disappointing aspect of the club for a member like myself.....it stems I understand from the original documentation and creation of the club which states it relates to the preservation of original cars. I honestly don’t know why they don’t consider changing the charter of the club, I’ve done that before in other clubs, but that is for the leaders of the club to consider. So, instead I will use this forum of a way of providing information to replica owners on originality, and practical departures they might make to achieve a practical yet high standard. It will also be a useful source of info to new buyers of replicas so they can determine how accurate the replica is......if that is important to them. I absolutely hate some replicas that depart radically from original, where they mix overly modern style components with the original 1930’s design of the car......and are just plain ugly in their treatment of various features on a car.
Regards Jerome
- AuburnNut
Topic Author
That’s marvelous! Thanks so much for either digging out the photo, or, going to the effort of making a new photo of an original interior....brilliant. I think this photo proves the 3 decorative lines at the top of the panel DO match the curve of the top of the door, AND they DO have a hard edge at the point they turn. It also shows the top line of the flap does broadly match the shape of the top of the door, but it is still fairly straight. It’s interesting that the top of the flap appears to be sewn down onto the panel with a brass fixing point on either end. I have not yet seen this on any car out there today (I’d say almost all cars have been redone without this feature).
Lastly, the red color Appears to be a darkish shade but it is not as dark as my wine/burgundy color.
Curt....thanks so much for getting that photo. This is very helpful to recording originality. Well done!
Regards Jerome
- AuburnNut
Topic Author
Does any person in the ACD club, to your knowledge have definitive expertise on interiors. Presumably our ACD club has judges of authenticity ....because it is hard to judge a concours without knowing the facts. That being said, I have owned very rare Rolls Royce and Bentley motor cars, and I know for a fact that the expertise in concours judging does not exist in many of the various clubs....particularly in interiors.
Now I have an Elegant Motors Speedster replica, so obviously that car doesn’t count in terms of originality. It’s a very well built replica, but It will never be in an ACD concours. I’m just trying to produce a car that’s sympathetic to the original.....in a sense it pays homage. So I guess I’m suggesting that the best we Replica car owners can do is produce an interior that makes us individually happy, but is sympathetic to the original. If we understand the original features, we can make reasoned judgements over departures from the original.
Regards Jerome
- AuburnNut
Topic Author
Thanks for your reply and contributing to the discussion. I’m not surprised Salmon was not an original color of leather from the factory. I personally think it looks great on that particular car, as it contrasts well to the sage colored paint....and was clearly an owners choice.
1) Can you tell us what were the original leather colors from the factory?
2) re the differing features I have highlighted in several door card photos (eg 1: the shape of the 3 lines, do they have a hard or soft turn on original car’s etc), as a very experienced ACD member and expert, what is your view on what is original.
Regards Jerome
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
- AuburnNut
Topic Author
Mike. I certainly considered these “T” nails which go into the outer edge of the door in the top corners but decided not to do so for two reasons...
1) I don’t know where to buy them....do you? As it is your suggestion, maybe you do know where to buy them. If so, I’d love to know.
2) they are a nails, and as you say, how do you fix that into fiberglass. The original car’s have a wood frame so that is possible to nail them into the corners.
For the benefit of other members reading this, I am attaching a photo of these “T” nails on an original car. I do this because I would like to have this forum document useful reference info for members restoring their car’s, rather than referring to things that perhaps others may not be aware of.
Thanks Mike for the reference to “T” nails as I had forgotten to highlight that is a feature of the original car’s....albeit small.
Regards Jerome
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
- AuburnNut
Topic Author
- AuburnNut
Topic Author
- AuburnNut
Topic Author
Regards Jerome
- AuburnNut
Topic Author
Here is my almost finished door card. It has been built from scratch as my car had no door cards when bought...it was an unfinished car. You will see that I matched the design of the original door cards, which was difficult to do, particularly the raised sections and the edges. There are a few differences to the original but it’s really quite close. I see lots of awful interiors in replicas, and a number of pretty bad redone interiors in original car’s. I hope you like these. I have yet to fit the interior door handle
Regards Jerome
- AuburnNut
Topic Author
Section 1 refers to the shape and style of DOOR CARDS.
Section 2 refers to the shape and style of CAR SEATS, and
Section 3 will refer to DASHBOARD AND INSTRUMENTATION.
Section 4 will refer to STEERING WHEELS AND STEERING COLUMNS.
Section 5 will refer to GEAR SHIFTERS/HANDBRAKES/BRAKE PEDALS .
It will take me some time to post the information I’d like to, so I would suggest that you try and let me finish all sections before you comment. .....or feel free to send me a private message.
Kind Regards Jerome
