- Thank you received: 44
810 trunk interior
- wynlaidig
Tim Gilmartin wrote: Picture of gas fill tube covering; note rust from wires that held it on the tube. Jack hold down straps with flat washers still stuck to the webbing.
Tim Gilmartin wrote: Picture of backing material for the burlap; note faint outline of the “x” cross member of the back seat. Burlap with finer lines. Non burlap lined material was on the trunk side of the gas fill tube cloth wrap. The gas fill tube side is a tan/olive drab color.
Tim.
Tim Gilmartin wrote: Here are some pics of my trunk material as found on my Westchester in 1992. I have no reason to believe that this is not original material.
- Michael R
- Thank you received: 18
- Michael R
- Thank you received: 305
Kindest regards,
Terry Cockerell
Australia
- Michael R
- Michael R
- Michael R
- Michael R
Jonathan Richards wrote: Mr. Richards, 1937 Cord S#32410S , which you previously owned , is a Beverly sedan and NOT a Phaeton. Foolish old man. You should know better , and used to. The other Mr. Richards with clearer brain.
Dear Mr. Richards, it is the best sign of a good charakter if you can make a joke about your own mistakes! you are a great man!
to John Mereness, wich details do you want? I´ll do my very best to help
- Jonathan Richards
- Thank you received: 24
In the background is the original piece from behind the rear seat, it has thick black lines.
To the RHS is the sample supplied by Rick Hulett which has thin black lines with a finer pattern.
At the lower LHS is the material I made up. It is based on the original sample but I made the lines too thin. I was not looking at the bigger picture at the time. With care I can salvage the job by redrawing the lines thicker.
So we have two distinct line patterns, one with thick lines in early production cars and one with fine lines in later production cars.
I believe the background colour was all the same. The sample of the original material in the picture has faded a lot.
My Cord has Serial No 1586 A, I have no idea when the line pattern changed.
- Jonathan Richards
RumRunner wrote: All,
May, I talk you into more trunk photos too, including trunk floor and ...) ?
Thought I would capture and post pictures of the trunk fabric in my 812 Beverly. No idea if it is original but sure looks like it to me. Hope these can be of some help.
-Michael
Michael R wrote: some pics of my unrestored 36 Westchester Nr. 704 Dimensions visible. The carpet has got a linnen protection arround and may have been nailed to the wooden platform
May I talk you into sticking your head into your trunk and doing some more detailed photos (including some overall, in corners, and ... ) ?
While Gai and I were in the Auburn Hospital in 2018 Zoey was in the Grand Parade with her friends the Butler family. She had a ball in the Butler's 1919 Auburn tourer.
I have already experimented with redrawing the lines and think it will work out ok.
The attached pictures show Zoey on the left with Taylor on the right
Cheers from Down Under,
Terry, Gai and Zoey
Having only one of the original clips in my trunk I was delighted to discover new clips and eyelets are available from Restoration Specialities in Winberg PA
They are called BURCO Clips.
Double Stud #8 X 3/4" ......................... Part No B112
Eyelet .......................................................... Part No B158
Washer ........................................................ Part No B33
Two sets are required.
Perhaps you can get Tim to copy and email you your judging sheet?
- wcoye
My 2 cents
Bill Coye
Westchester 2240A
Brag line: Winner of the
- STEVEN.KUIPER
- Thank you received: 17
When I suggested to my wife that I could remove the lining panels and redo the lines to widen them ................. she replied "DON"T EVEN THINK ABOUT IT!"
I guess it stays.
body. This can be accessed by removing the spare wheel but that is a chore. I modified my trunk shelf so that it has a removable section in the RHS above the void. It is hidden away by the carpet over the shelf.
To access the compartment you just have to pull back the carpet and remove the lid. There is a lot of space for a screw jack, modern hub cap removing tool, heaps of other tools and spares. I also fitted a small panel so that the stored items would not damage the fuel tank filler sleeve.
This leaves the rest of the trunk free for everything else or clear for car shows.
- Thank you received: 136
- john mccall
- Thank you received: 34
- Jonathan Richards
- Michael R
Thanks for posting these pictures. There is only one Beverly that I know of in Australia and it has been customised to some extent. Others will have to comment on these pictures.
Can you add a picture of the inside of the trunk lid please???
Terry Cockerell
Australia
- RumRunner
- john mccall
I stand corrected. There are 2 jute panels, one on the back side of the rear seat with lines facing forward, and another at the front of the trunk with lines facing rearward. I will have to make sure I refresh my memory by looking at what I did before commenting the next time.
Check the attached layout diagram.
On another note I made a drawing of the wires that pass through the head lining which is full size and can be used to make new stays in stainless steel.
- john mccall
I am surprised however that the lines show on the back side of the rear seat as Rick told me, and his installation instructions say, that the lines should face forward on that piece of material with the raw jute showing in the trunk. Since he didn't have a source for the raw jute he said just turn the piece so the lines face forward.
- john mccall
Rick , trying to make a buck specializing in interiors, was at the same time extremely free with his knowledge and time, to individuals trying to restore their cars. Hats off to that attitude.
I can see that gathering restoration info is generally popular with those that read and replied to this forum. Is there also a more widely read forum that would reach more eyes?
This looks like the original trunk lining material that has faded with time and new carpets. This trunk lining has a fine line spacing.
I saw another Cord in the park in 2018 with the same material. I took some pictures of the lining but can't find them. I will keep looking.
Found them! Rick Hulett told me this greyish material had faded a lot and was originally the colour shown in the attached small sample in the last picture.
In the park I just happened to be photographed while taking my pictures.
I also think we should add an original factory photography and new car photography page divided into A, C , & D and grouped by key model years (ex Auburn 1934 - 1936) - I would be pleased to moderate such.
