Need help re Master Cylinder Re-build
  • Neal Ziff
15 Jun 2009 02:58 #13759 by Neal Ziff
Replied by Neal Ziff on topic Need help re Master Cylinder Re-build
Stainless it is. I've got referrals now for a few places. I'll be checking out the wheel cylinders next.
Thanks everybody,
Neal
Neal
_________________
1930 8-95 Cabriolet
  • mikespeed35
15 Jun 2009 02:24 #13758 by mikespeed35
Replied by mikespeed35 on topic Need help re Master Cylinder Re-build
As Tom said, I would use a stainless sleeve instead of brass. There are many places that do this type sleeving. Assembling the master cyl. after you have it sleeved is no big deal. You must keep in mind that some Co. that sleeve master cyl. and wheel cyl. will guarantee them from leaking if they rebuild the cyl. themselves, but not if you assemble the cyl. You probable should think about having the wheel cyl. sleeved also unless you can still get new ones.
  • Tom_Parkinson
14 Jun 2009 15:59 #13753 by Tom_Parkinson
Replied by Tom_Parkinson on topic Cylider sleeving
Hi,
I had my master sleeved with stainless at www.brakeplace.com . My brother has had his 37 Chevy cylinders (Those weird "Huck" brakes) done there also. Both jobs came out superbly well done.
Price was reasonable.
  • Neal Ziff
14 Jun 2009 03:59 #13750 by Neal Ziff
Thanks Mike. Another member recommended sending it out and having it professionally done. He recommended Apple Hydraulics. I'm pretty mechanically inclined, but my backround is not cars. I have never done this before, but am not intimidated. Bottom line is, I don't want to compromise my restoration. What would you recommend?
Neal
Neal
_________________
1930 8-95 Cabriolet
  • mikespeed35
14 Jun 2009 03:38 #13749 by mikespeed35
Hi Neal, I hope you intend to resleave the cyl. I don't have that year Auburn but NAPA probably has most of the stuff you need. A whole kit would be best.
  • Neal Ziff
13 Jun 2009 21:15 #13745 by Neal Ziff
Need help re Master Cylinder Re-build was created by Neal Ziff
Does anyone have any advice on where I might find what I need to rebuild the master brake cylinder for my 1930 8-95? I'm soaking it right now so that I might be able to disassemble it, but anticipate needing to replace the cups. I also do not have the boot that covers the shaft.
Of course, any words of advice regarding the process would be appreciated.
Neal
Neal
_________________
1930 8-95 Cabriolet
