Stop Leak
- auburn653
21 Feb 2010 18:35 #15986
by auburn653
Replied by auburn653 on topic Stop Leak
Mike, wish I would have known that stop leak trick before I rebuilt my engine... that would have kept the oil from leaking out the tailpipe!
- oldbanger71
20 Feb 2010 20:59 #15979
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic Stop Leak
do it the african way : if you are in the middle of no where, go to the next place where you can find eggs put one in your radiator and run the engine until the eggs are drawn to the leak, as the water heatens up it will cure at the leak from inside, let the engine cool and top up with water as soon as you can. Note this is only a temporarly fix and should be corrected as soon as possible ( in Africa that will never happen ) allthough i saw this personaly in Africa, i would neither recommend to do so, nor can garantie that it'l work or is removable afterwards. All i can say is, it safed us then, it's inviromentaly friendley and easy accesible anywhere. Don't use one strout's egg or similar !! <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
- Thank you received: 19
20 Feb 2010 19:26 #15977
by balinwire
Replied by balinwire on topic Stop Leak
I used radiator stop leak, it stopped the leak, but slowed the flow and leaked past the water pump bearing seal and the pump main bearing seized. The coolant is a lube for the pump main bearing, the sealer is silica, one of the guys claimed household black pepper will seal the leaky.
- Greg Frownfelter
20 Feb 2010 12:09 #15971
by Greg Frownfelter
Replied by Greg Frownfelter on topic Stop Leak
the question is did it continue to leak
- Chris Summers
20 Feb 2010 06:15 #15970
by Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
Replied by Chris Summers on topic Stop Leak
In a way it worked...
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
20 Feb 2010 05:15 #15967
Stop Leak was created by mikespeed35
I was in the local NAPA store and they told me about a incident that happened in another store. A guy came in and ask for some Stop Leak. The counter man ask him what brand he wanted and he didn't now so he suggested Bars Leak with all the pellets works real well. The guy bought the Bar Leak and went right out in the parking lot and put it in "the crankcase" They said the motor ran for about 3 minutes and then didn't!!
