1935 -36 Auburn Headlight
- auburn653
03 Aug 2009 13:17 #14132
by auburn653
Replied by auburn653 on topic 1935 -36 Auburn Headlight
- oldbanger71
03 Aug 2009 09:31 #14130
by oldbanger71
812 310 121 S
Replied by oldbanger71 on topic 1935 -36 Auburn Headlight
and make sure it can't drop on the bumber and brackets too !
i usualy put some flexible sealer-paste (Which keep flexible with the years) on the lense when putting back together to prevent next time that i drop a lense ( it holds the lense to the bezel ). <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
812 310 121 S
03 Aug 2009 01:40 #14128
by ilikescars
Replied by ilikescars on topic 1935 -36 Auburn Headlight
Murray: You described perfectly how to do the job. Best thing to do would be to spread couch cushions, pillows, blankets foam rubber, etc. below your work area, just in case you drop the lens.
- Murray Hall
03 Aug 2009 01:07 #14127
by Murray Hall
1935 -36 Auburn Headlight was created by Murray Hall
I have a restored 1935 851 sedan . The filament in one headlight burned out. I have a new bulb to replace it but am apprehensive about tackling the job as I certainly don't want to break the headlight lens. Does anyone have any tips on how to do this ? I know that you have to loosen the screw in the bottom and shove in on the lens. Any help would be appreciated. Thanks!!
Murray Hall
Murray Hall
