- Thank you received: 19
interesting motor design
- bill powell
- R Coleman
Bob
810 2350H
812 31649S
- bill powell
Our old Buick was about worn out, so we didn't have to oil the air tools.
If you try and drive it with four to save gas you would save a lot. Because it won't go anywhere, thus the savings.
- bill powell
'The way the factory four barrel manifold works is that it thinks it's feeding two V-4 engines. One side of the manifold feeds the odd number cylinders, and the other side feeds the even number cylinders. You just blank off the side of the carburetor that is going to the dummy pistons. You can wire the plugs if you want, for looks.
You can build one yourself by just eliminating the pistons, and bolting an extra rod cap to maintain crank oil pressure.
- Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
Have you driven the 4-6-8 Cadillac's of the eighties? Is there a running one in your barn. Could that idea return? I heard it had some drivability issues possibly that could be corrected with todays computers.
- bill powell
- Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
It looks like you could build anything in that shop.
What a waste to to be inventing an engine that can run on water.
- Chris Summers
(there needs to be a smiley on here for envy)
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
en.wikipedia.org/wiki/Crower_six_stroke
www.autoweek.com/apps/pbcs.dll/a ... WEEKSISSUE
