Seat Belts?
- HawkHunter
Second, if seat belts are to have [i:2k4k5694]any[/i:2k4k5694] value, they must be fastened to the frame of the car, or through large plates to the floor of the car. (4 X 4 X 1/8 mounting plates are required by SCCA.) And, the belts must extend to the rear at the same angle that they cross your lap. See
[url:2k4k5694]http://www.wescoperformance.com/lap-belts-install.html[/url:2k4k5694]. So in sedans they will interfere with the feet of rear seat passengers. Never fasten the belts to the seat frame. In the event of a head-on collision the seat (especially the wood-framed ones) with you attached will tear from its mountings and fly forward, increasing the likelihood of injury.
I do not believe that 3-point belts are practical in our cars. A head-on collision develops G-forces sufficient to rip the center pillar right out of them, even the sedans.
Our cars lack all of the safety amenities we have gotten used to in modern cars --- crumple zones, collapsing steering wheels, 3-point belts, airbags. There is nothing we can do to simulate these. So can we drive in safety?
Of course we can. You can enjoy your car on the road while you keep its limitations in mind. Concentrate on the road and drive very, very defensively. Drive secondary roads when you can. They are much more fun, too. (When Henry Portz and I drove to Auburn in Moonshadow last year, accompanied by three other Cords, the [i:2k4k5694]only[/i:2k4k5694] time I felt a bit concerned was when we were forced to use I-69 for a time. Man, that Interstate traffic does move along swiftly.)
Here endeth the lecture.
- Mike Dube
8-100A
- Joel
- Chris Summers
If I was driving an old car by myself, I probably wouldn't have lap belts installed UNLESS it was a car like Josh's Moonshadow that gets driven very regularly (or on long tours). If I was driving it with others, as a family car, I would do everything possible--radial tires, 12-volt lighting, belts, cut-off switches, the works--to make it as safe as possible.
P.S. To answer your question, Joel: My suggestion would be to put on belts if they make you feel any better. And I doubt those poor people in Michigan would have made it. In a phaeton (or speedster, for that matter, or any open car) there's not much between your head and the pavement in a rollover, even if you are strapped in.
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- Joel
With a wood body structure, how likely is it that the body will separate from the chassis in a severe crash? Should you strap yourself to the body or the frame? Or take your chances without belts. How about the tragic Duesenberg crash up in Michigan? Would the 3 fatalities have survived if they were belted in?
I don't have belts in my Auburn Speedster simply because I don't know what is the safest thing to do. <!-- s:?: --><img src="{SMILIES_PATH}/icon_question.gif" alt=":" title="Question" /><!-- s:?: -->
- cbsIII
Installed 3-points back in '98, mainly because of the ability to install child seats in the back. They make for a bit better comfort level, as driving without seat belts seems odd these days, legal or not, in whatever country. There's no way I could transport my kids without belts, ACD car or not.
Purchased from Moss Motors (online), it's a Bean product made in Oklahoma, looks vintage with nice chrome buckle.
Rears go back through upholstery gap at bottom of seatback, and at top of seatback between tonneau cover and upper, anchors on structures already there without drilling. Easy to hide if displaying the car. Fronts are drilled through the floor behind the front seat, and upper runs back to the quarter-window front mounting bolt, replaced with stainless bolt for driving. Harder to hide, but they sit on the rear floor under the coolers. It took a while to conceive of actually drilling 4 non-stock holes in the floor sheetmetal, but it's better this way. Some day somebody will hammer weld these holes closed for restoration. Until then, this is the way to go if you drive it. (Wonder if aftermarket air bags will fit?)
CBS
[/i]
"I work for the Auburn Automobile Company. I am not an automobile race car driver although I hold more world speed records than any other man in the world" -Ab Jenkins 1937
- Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
I don't really know the answer on child seats, but most state DMV regs are online.
- Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- sds1861
I concur with your thinking on the child seats. By the way; while I have you, what is the correct spark plug for the Model-J Duesenberg?
Steve
- Chris Summers
Chris Summers
ACD Club
CCCA
H.H. Franklin Club
- sds1861
Steve Stevens
- Mike Dube
As far as I know, the federal govt & the various states do not force you to add belts, turn signals, or other things not required in the year your car was manufactured.
8-100A
- Ric Simpson
I was thinking of adding a set for front seat passengers. They will hold me in position as the non-collapsible steering column gets pushed through my chest in a major front end collision. Any suggestions where to anchor them? Ric.
Ric Simpson,
2001 Niagara Parkway,
Fort Erie, Ontario,
Canada. L2A 5M4
