Super charger, Operation.
- bill powell
19 May 2008 03:29 #10126
by bill powell
Replied by bill powell on topic Super charger, Operation.
Ford, Studebaker, and others.
19 May 2008 01:33 #10125
Replied by mikespeed35 on topic Super charger, Operation.
Another push through the carb. is 57 Ford blower. They work very nicely with 300HP of 312 Y-Block.
18 May 2008 20:41 #10120
by Josh Malks
Replied by Josh Malks on topic Super charger, Operation.
There are actually even more sub-categories of blowers, based on whether they are driven by exhaust gases (turbo-chargers), by a gear train from the engine or by fan belts. Positive-displacement superchargers may be either Roots type (2 or 3 interlocking lobes) or vane-type. Centrifugal blowers are essentially a fan. The Cord used a centrifugal supercharger, driven by bevel gears from the center of the camshaft.
- alsancle
- Thank you received: 16
18 May 2008 20:11 #10119
by alsancle
Replied by alsancle on topic Super charger, Operation.
Blowers can be divided up between roots & centrifugal, and then further between those that push through the carb and those that pull. Further still, but constant and on-demand.
If you are interested, check out my page on Stutz blowers which I think were the neatest of all, activated by the driver they pushed through the carb. A very similar setup to the pre-war Mercedes Benz. While Mercedes perfected theirs, the Stutz setup wasn't quite right. George Holman has recently worked the kinks on his dyno and figured out how to get a push blower working perfectly.
home.townisp.com/~alsancle/Stutz ... arger.html
- bill powell
12 May 2008 21:21 #10056
by bill powell
All superchargers, regardless of how they're driven, do the same job. They provide more air than normal atmospherics can provide, and to maintain your 15:1 fuel gas ratio. allow the engine to accept more gas.
More horsepower.
'About the only alternative is to inject the engine with pure oxygen.
More horsepower.
- archhist88
12 May 2008 14:11 #10055
by archhist88
Super charger, Operation. was created by archhist88
Seeking old discussion, or new about how the super charger operates.
Bart
Bart
