Fuel Pressure specs for a Model J with Updraft carb???
- Bob Roller
Bill is right,if one of these engines were to be "blueprinted" and high compression pistons installed,I think possibly 700 HP might be possible.
Bob Roller
Built to 283 cu in/283 HP specs the J was probably a 700 HP engine. Just getting rid of the Shebler and going to a down draft carb was good for a sizeable HP increase.
I think you need to spend more time finding out why your needle valve isn't working and less time changing fuel pressure.
- Bob Roller
Bob Roller
- Mike Dube
It was up to about 145hp when they panned away.
click here: www.jaylenosgarage.com/segment/r ... -the-dyno/
8-100A
- Bob Roller
There has been a lot of speculation about the true power output of these engines. With the low compession and fuels available in the early days of the "J",the fact they ran as well as they did said a lot for this design. At the time the "J"engine was being made,Lycoming was making an "L"head (flathead) engine of identical displacement and it was rated at about 100 HP. The efficient intake and exhaust system of the multi valve "J" engine at least doubled this and probaby even more than doubled it.
I think it was Don Vordermann writing in 1973 in the Automobile Quarterly who was probably right when he stated that "as delivered"the "J" probably didn't put out the advertised 265HP and that 245 to 250HP was
probably a more realistic figure. He also went on to say that the performance of these cars was far beyond the cars that were then offered to the luxury buyers of that day. I have personally compared the "J" to the Cadillac V8-V12-and V16 as well as the Packard "Super"8 and the 12 and it is hands down in favor of the Duesenberg by a wide margin.When warmed up as we did with SJ528 it was still yet another story.The 3.875 bore gave the engine about 450CID and the supercharger was not needed and could have been a liability if used on that particular modification. One thing for sure,it moved that heavy Brunn bodied car in a most satisfactory manner and did it with no real effort.
Bob Roller
- Joel
I noticed on a video on Jay Lemo's Garage that they Dyno'ed a Model J straight 8, and they had the fuel pressue set at 1.5 psi throughout the entire pull. Very interesting, maybe I will try that.
- Mike Dube
I wish you luck, but for what it's worth I had trouble with that one, and I tried two of them. I live near Summit Racing in Ohio and they were good about taking both back. I spent a little bit more $$ and got one mfd. for Holley that works fine. This one adjusts with an allen wrench and has a port for a guage.
8-100A
- Bob Roller
Check the nuts holding the intake manifold onto the head.If they are not tight,an air leak can mess up the idle.
Check this on a cold engine. Also make sure the carburetor base screws are tight also. I had a Packard years ago that had a less than tight carburetor base and it idled poorly if at all
Bob Roller
- Joel
... 6eD0yiT3bs
The fuel pressure regulator showed up today, soon it will be installed and tested.
- Joel
I did go thru the carb last fall, I found a reprint of the full adjustment process on line. It seemes to work OK the first time I ran it after the carb was cleaned up and adjusted, but has not done so consistantly.
Since Mike's book says 3 psi, I am going to see if I can find an adjustible regulator to turn down the pressure a tad. The electric pump has an internal, non-adjustable pressure setting.
Edit: found one at Summit, I think I'll try it. www.summitracing.com/parts/MRG-9710/
- mdsbob
That should be a good start to getting the carburetor properly adjusted.
- xjn001
- xjn001
- Joel
- xjn001
- Joel
