Update Info - 1931 Franklin Duesenberg Lens (updated Info)
01 May 2022 17:19 - 01 May 2022 17:19 #45316
Replied by johnmereness on topic Update Info - 1931 Franklin Duesenberg Lens (updated Info)
A 1930 Franklin uses an 11 1/2 inch lense and they also fit Duesenberg.
A 1931 and 1932 Franklin uses a 12 inch lense and my understanding is they are unique or may also fit a Marmon.
11 1/2 have been reproduced over time
12 inch is a pretty rare lense still
Sorry, no pot of gold, but still work a solid couple hundred dollars if 12"
Last edit: 01 May 2022 17:19 by johnmereness.
- Justin Kerns
- Thank you received: 8
30 Mar 2022 00:40 #45092
by Justin Kerns
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
Replied by Justin Kerns on topic Update Info - 1931 Franklin Duesenberg Lens (updated Info)
I believe Model A Duesenberg used Monogram lenses but am unsure of the diameter.
Justin
25 Mar 2022 03:53 #45069
Replied by mikespeed35 on topic 1931 Franklin Duesenberg Lens
I think Franklin are 12".
- Jeffedit88
25 Mar 2022 01:42 - 25 Mar 2022 01:43 #45065
by Jeffedit88
Replied by Jeffedit88 on topic 1931 Franklin Duesenberg Lens
Thank you I will look for the marking.
Last edit: 25 Mar 2022 01:43 by Jeffedit88.
25 Mar 2022 01:24 #45064
by pete kelly
Replied by pete kelly on topic 1931 Franklin Duesenberg Lens
The size of the lens is embossed on the lip under the ring.
Duesenberg used 11 1/2"
- Jeffedit88
24 Mar 2022 21:15 - 27 Mar 2022 23:05 #45063
by Jeffedit88
Update Info - 1931 Franklin Duesenberg Lens (updated Info) was created by Jeffedit88
I have pair of what are labeled 1931 Franklin Duesenberg Headlight Lenses. I am looking for more information on what they might go on or if the the label is correct. I am cleaning out my fathers storage and we mostly have classic car parts for American cars but I found a set of lenses.
Also what is a good place to list them for sale?
They measure 12"
The Lenses have written on the glass:
MFG. BY Monogram Lens Corp.
Detroit Mich USA 12 IGC
PAT 11-23-20. 7-3-23. 3.29-27.
Twilite Lens
Twilite Headlamp
They measure 12"
Twilite Lens
Twilite Headlamp
Last edit: 27 Mar 2022 23:05 by Jeffedit88.
