Adjustable Steering Wheel
- Rlamb10769
20 Mar 2020 20:26 #39769
by Rlamb10769
Richard Lambert
ACD #3371
Replied by Rlamb10769 on topic Adjustable Steering Wheel
Mike just did the adjustment and the frame is slotted.
Richard Lambert
ACD #3371
19 Mar 2020 04:38 #39759
Replied by mikespeed35 on topic Adjustable Steering Wheel
Yes, those are the ones. Don't recall if they are slotted.
- Rlamb10769
18 Mar 2020 11:00 #39750
by Rlamb10769
Richard Lambert
ACD #3371
Thanks Mike,
Is it the three bolts through the frame that is wire tied that holds the steering box? Are they slotted or how do they move? I assume they might not need to be slotted because it will be a very small movement at the box, correct?
Richard Lambert
ACD #3371
18 Mar 2020 04:47 #39745
Yes, the steering box needs to be loosened if you change the height. Retighten after you finish your adjustment.
- Rlamb10769
17 Mar 2020 17:19 #39739
by Rlamb10769
Richard Lambert
ACD #3371
Adjustable Steering Wheel was created by Rlamb10769
Has anyone tried on their L29 to adjust the steering wheel height?
I see how to move the column up and down under the dash but does the steering box need to be loosened or adjusted?
Richard Lambert
ACD #3371
