Transmission Fluid level
30 Sep 2019 04:03 #38487
Replied by mikespeed35 on topic Transmission Fluid level
The trans and dif. share fluid. The ring gear throws the fluid to a trough that sends it to the trans. where it runs back to the dif. The way to fill is put the oil in at the trans filler plug until it runs out the dif. level hole.
- Rlamb10769
23 Sep 2019 13:21 #38425
by Rlamb10769
Richard Lambert
ACD #3371
Replied by Rlamb10769 on topic Transmission Fluid level
Got it, 5qts and overflow pipe plug on back of diff about 1/4 up.
Richard Lambert
ACD #3371
- Rlamb10769
20 Sep 2019 16:18 #38418
by Rlamb10769
Richard Lambert
ACD #3371
Transmission Fluid level was created by Rlamb10769
I check the fluid level in the transmission and there is only about an inch of fluid on the stick.
Not sure if I am doing it right. Also could not find the capacity of it.
Any information would be appreciated.
Richard
Richard
Richard Lambert
ACD #3371
