recommendations for rod bearing service
- charlesflick
27 Sep 2017 17:18 #33606
by charlesflick
Charles Flick
Replied by charlesflick on topic Re: recommendations for rod bearing service
I am rethinking the rod bearing issue. Is the reason you lose oil to the wrist pins and piston, is that the bearing inserts don't have a hole that matches the rods? You babbitted your cord rods?
Charles Flick
06 Dec 2016 21:59 #31988
Replied by 1748 S on topic Re: recommendations for rod bearing service
I was told by someone that any babbitt bearing older than 30 years needs to be replaced. I'm not sure why this was told to me because I did not ask the big question... Why...
- Thomas Wilcock
- Thank you received: 8
23 Nov 2016 11:07 #31932
by Thomas Wilcock
Replied by Thomas Wilcock on topic Re: recommendations for rod bearing service
The problem I see with using inserts is that you lose the oil feed to the wrist pins and also the squirt hole which shoots oil to the thrust side of the cylinder walls as designed by Lycoming engineers. This extra oil up top would also help to take heat away from the top end. The babbit also goes right to the outside edges of the rods and around the radius at one end and thus gives more bearing contact surface. I have 72,000 miles on my 4 cylinder Indian motorcycle which I babbited myself and it still runs 45 LB oil pressure. I have just finished babbiting my own Cord engine. Tom
- Jonathan Richards
- Thank you received: 24
23 Nov 2016 04:39 #31927
by Jonathan Richards
Replied by Jonathan Richards on topic Re: recommendations for rod bearing service
Just so there is no confusion out there ,some of us purists still employ babbitted main and rod bearings in our Cord FB and FC engines. I know they are old fashioned and technologically old school but they do the job. Going back to my earliest days of automotive experience as a base for opinion it seems to me if babbitt was good enough for 4-cylinder Model A Fords and 12-cylinder Auburn 12-160s it is good enough for my 8-cylinder Cord Supercharged. Commentary anyone? Happy Thanksgiving.
- Joel
17 Nov 2016 13:59 #31919
by Joel
Replied by Joel on topic Re: recommendations for rod bearing service
If you want to stick with Babbitt for some reason, Harkin Machine in Watertown South Dakota is the place to go. (605) 886-7880
17 Nov 2016 13:32 #31918
Replied by Curt Schulze on topic Re: recommendations for rod bearing service
You are correct Mike ! Auburn engines use MoPar rod bearings and Allis Chalmers mains.
17 Nov 2016 04:37 #31917
Replied by mikespeed35 on topic Re: recommendations for rod bearing service
I think most people us inserts now days. I'm sure I will be corrected if wrong.
Cordially Mike
Cordially Mike
- charlesflick
17 Nov 2016 00:40 #31916
by charlesflick
Charles Flick
recommendations for rod bearing service was created by charlesflick
I need to have my rod babbitt bearings redone. Anyone with a recommendation or warning would be much appreciated. Was thinking of using egge
Charles Flick
