Drivers Door Question
30 Oct 2016 13:34 #31878
by Tom_Parkinson
Replied by Tom_Parkinson on topic Re: Drivers Door Question
Hi Gary,
My door does not have this notch. I think your door was modified post-production.
It strikes me that left-and right-hand RVM's are [i:1bpxzb6u]de-rigueur[/i:1bpxzb6u] on the sedans unless you want to drive by the "contact method."
A possible solution,: years ago I saw sedan with a nice chromed RVM that was mounted on a mostly-horizontal chromed pedestal at the rear end of the fence/grille. The owner told me it was a Harley Davidson accessory and that the hole was already present. I have not checked it out.
29 Oct 2016 00:31 #31874
by
Replied by on topic Re: Drivers Door Question
Looks like they tried two styles R.V.Ms. Makes driving a lot less stressful. Somebody's got a R.V. out there that doesn't require drilling or milling away the sheet metal, seen it but have no photos.
Cort
Cort
- GOENKA
28 Oct 2016 05:34 #31872
by GOENKA
Replied by GOENKA on topic Re: Drivers Door Question
looks like an aftermarket mod to fit the rear view mirror bracket which was probably fouling with the A pillar so they cut into the door
29 Sep 2016 19:14 #31780
Drivers Door Question was created by 1748 S
In the supplied pics of my drivers side door edge there has been some metal removed. Was this a factory design or some type of aftermarket attempt to install a rear view mirror? I included a pic of the outside rear view mirror placement I took off about a year ago.
