- Thank you received: 57
Torque setting on wheel lug bolts
- Tim Gilmartin
26 Sep 2016 19:55 #31772
by Tim Gilmartin
Replied by Tim Gilmartin on topic Re: Torque setting on wheel lug bolts
I've been using 90 foot/lbs dry for years. Seems to work well.
25 Sep 2016 02:47 #31766
Replied by mikespeed35 on topic Re: Torque setting on wheel lug bolts
Caution on ARP lub. Not to be used on non ARP fasteners!!!!
Cordially Mike
Cordially Mike
22 Sep 2016 07:13 #31759
by
Replied by on topic Re: Torque setting on wheel lug bolts
I have not found any bolt torque specs for stock wheels/hubs.
On the Richardson driveshafts and hubs 95 lbs ft (no mention of lube on threads)on the lug nuts.
On Don's wheels 110 lbs ft (ARP lube on threads).
Frank
Frank
- Thank you received: 304
20 Sep 2016 04:53 #31748
Replied by Terry Cockerell on topic Re: Torque setting on wheel lug bolts
I cannot remember where I read or got the setting that I use but it is 90 ft lbs.
I have driven my car 10,000 miles in 5 years and have not had any trouble.
I had also fitted replacement steel rear hubs and Richardson drive shafts.
The real problem is the original cast wheel hub flanges are too thin and flex.
Regards,
Terry cockerell
Regards,
Terry cockerell
20 Sep 2016 02:55 #31747
Where did the torque figures come from that were mentioned?
Cordially Mike
Cordially Mike
- Thank you received: 135
17 Sep 2016 15:04 #31727
Replied by 1748 S on topic Re: Torque setting on wheel lug bolts
Thanks for the torque setting for the lugs. Seems I was off by lots on a dry thread but not far off of a lubed thread.
- pcsteb
17 Sep 2016 14:56 #31726
by pcsteb
Replied by pcsteb on topic Re: Torque setting on wheel lug bolts
72 lbf with lubrication or 120 lbf without.
Under-torqued lug bolts are known to result in cracked wheels.
16 Sep 2016 13:55 #31724
I don't believe anyone has ever mentioned this before. Personally on all my cars or trucks it's a "feel" torque. I know many newer cars do have a torque requirement and the "feel" torque is not correct for them. So without really knowing the 36 or 37 lug bolt torque I need to guess it to be around 50 ft lbs. Let's see how close I guessed. I will be watching this for an answer.
- Dennis Jolicoeur
16 Sep 2016 13:29 #31723
by Dennis Jolicoeur
Dennis Jolicoeur
Torque setting on wheel lug bolts was created by Dennis Jolicoeur
What is a good torque setting to torque the tire wheel rims on a 36 Westchester?
Dennis Jolicoeur
