Ebay "Transmission Cover"
- Thank you received: 135
Well tom best I can say is you both correct and incorrect. Best of my information is no Cord came factory with a 2 piece front trans cover but... Josh Malks had a fiberglass 2 piece modified cover just to eliminate removal of the front bumper. This particular cover is missing an important piece too. It appears from the pics to be well designed but still not correct. But if you were only interested in an easy driver. This may be the best way to work on the trans shifter and switches. Then again Richardson universals up front is a driver's way to go also. Just depends on how close you choose to stay to an original car that left the factory line...Tom_Parkinson wrote: Hi,
There is a purported 810/812 transmission cover listed on ebay. It looks like this:
I emailed the vendor to advise that it is NOT a Cord Transmission cover. He says we're both right--that this is a part that goes in front behind the bumper. I surmise that if he's correct this piece was a half of a two-piece cover, of which I have never seen or heard.
SO--is there such a thing as a two-piece transmission cover, and that this would be half of it? I'm really curious, and I am wondering if I owe this guy an apology.
- E L
- Thank you received: 25
It was the lazy way of servicing the cross shift switch without removing the bumper.
Why not use a chrome plated piano hinge!!!!!
