810 interior door panel removal
- wcoye
21 Apr 2016 01:10 #30986
by wcoye
Bill Coye
Westchester 2240A
Brag line: Winner of the
Replied by wcoye on topic Re: 810 interior door panel removal
Gentlemen, thanks for your help. Guess this will be a bit of an adventure!
Bill
Bill
Bill Coye
Westchester 2240A
20 Apr 2016 23:03 #30985
Replied by 1748 S on topic Re: 810 interior door panel removal
About all I can add is how the handles come off. They both have a spring behind the bezel. you need to press in the bezel so the pin that keeps the handle connected to the actuator. Press out the pin. then slip off the handle and then remove the bezel and spring. Sorry can't help with the actual door panel removal but it appears well said above. If you can will you please take pics so others might learn something? I do enjoy looking at pics.
- George van Nostrand
- Thank you received: 35
20 Apr 2016 22:01 #30984
by George van Nostrand
Replied by George van Nostrand on topic Re: 810 interior door panel removal
Bill, When Auburn built the Cord they used a rectangular door clip that had spurs on the corners. They must have inserted the clips in the doors, then pressed the panel in place and mashed them with a hammer which dug the spurs into the panel. These clips are obsolete, and being 80 years old may break when you pry off the panel. On a restoration the panel board needs to have holes using new clips to retain the panel.
Good luck.
George.
Good luck.
George.
- wcoye
19 Apr 2016 17:17 #30978
by wcoye
Bill Coye
Westchester 2240A
810 interior door panel removal was created by wcoye
Hi, I need to remove the front driver side interior door panel to repair/unjam the window mechanism in my Westchester.
What surprises can I expect? Can I use regular panel removal pry tools? Is there anything in particular I should look out for or be careful with the lift mechanism?
Thanx in advance, Bill
Bill Coye
Westchester 2240A
