- Thank you received: 136
Shift Solenoid Block
20 Jun 2015 03:13 #29785
Replied by 1748 S on topic Re: Shift Solenoid Block
Thanks guys for the quick responses. Will buy some rattle can paint and make it look good.
20 Jun 2015 02:58 #29784
Replied by mikespeed35 on topic Re: Shift Solenoid Block
If you are looking for the paint Krylon is spelled with a "K" not crylon.
Cordially Mike
Cordially Mike
20 Jun 2015 02:55 #29783
by
Replied by on topic Re: Shift Solenoid Block
You don't take it apart, spray with crylon dull aluminum
20 Jun 2015 02:02 #29782
Shift Solenoid Block was created by 1748 S
How do I remove this wire manifold from the solenoid block so I can cad plate it? It almost appears to have some bent over ears on the underside but instead of ruining something I felt it best to ask. I have already removed my clutch and brake pedal stop because I thought it was something a previous owner installed for the mechanical shifting this car had when it was purchased back in 1961. It was never a complete system as far as I know. I still have all the linkage from it.....
