Tail Light Lense
  • Tom Georgeson
15 Jun 2015 01:06 #29744 by Tom Georgeson
Replied by Tom Georgeson on topic Re: Tail Light Lense
While you are at it I suggest, for safety, that you paint the inside of the housings white and install bright bulbs. I use 14/50 watt incandescent bulbs I get from Bob Drake, Grants Pass, Oregon.
  • 1748 S
  • Platinum Forum User
14 Jun 2015 23:04 #29742 by 1748 S
Replied by 1748 S on topic Re: Tail Light Lense
Here are some pics. You can see there are 2 springs on each area. The rivets are brass too. Also note there is a top and bottom by the finger pointing to a drain hole.
  • Red Brick
14 Jun 2015 04:49 #29738 by Red Brick
Replied by Red Brick on topic Re: Tail Light Lense
Gary - Would you be able to post a picture of the fitting?
Albert
  • George van Nostrand
13 Jun 2015 20:58 #29737 by George van Nostrand
Replied by George van Nostrand on topic Re: Tail Light Lense
Gary; If you use one spring per rivet ( 3 total ) they will work just
fine, and you'll reduce the risk of breaking the lens.
George.
  • 1748 S
13 Jun 2015 17:29 #29736 by 1748 S
Tail Light Lense was created by 1748 S
In the tail light housing is a set of flat springs. They are held in the light body with rivets. Why are they doubled up on each corner? Do I really need to have 2 springs in the 3 different locations or can just one spring work fine? Thanks.
